Old 25-04-2008, 11:09 PM   #1
JimmyBAXR6
Default Au fan belt
Hey guys I need to get to the cam chain tensioner to fix an oil leak. the last ford i had was an EA (hence its been a while) although I also have a BAXR6 I brought in Nov 07, which has been a great car, however I can't figure out how to remove the fan belt....the EA had a tensioner pully you could loosen to get it off....can anyone help?
JimmyBAXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2008, 11:10 PM   #2
JimmyBAXR6
Sorry everyone its not the BA I am trying to fix its an AU ute
Old 25-04-2008, 11:18 PM   #3
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
yeah the au has a tensioner pully that you put a rachet on and pull on, it is spring loaded, if you push on the belt you'll see it move and see which way to move it to get the belt loose
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2008, 11:22 PM   #4
JimmyBAXR6
yeah i thought so. there is no hexhead on it though? are you talking of a special ratchet?
Old 25-04-2008, 11:25 PM   #5
tufLTD
tufLTD
tufLTD's Avatar
It's not a hex head, it's a 3/8" square, just use a 3/8 ratchet.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2008, 12:46 AM   #6
sly
Sly like a G6
sly's Avatar
If you're fairly strong you can lift the belt off one of the smooth-side pulleys with your hands then slide it off. This gives enough slack to remove it from the other pulleys. I usually take the thermo fans out first to give some room. I used to be able to put the belt back the same way but since I put a new belt on at around 300,000km I've had to use the ratchet handle. The new belt's my excuse anyway... soon I'll have gold chains, a convertible and a busty blonde LOL.
Sleeper, anyone?
Old 26-04-2008, 02:00 AM   #7
5.0 ED
5.0 ED's Avatar
hehe if gold chains gets me a busty blonde im in.
