25-04-2008, 10:20 AM | #1 | ||
I got a roadworthy done yesterday on my '93 XG, and the bloke came up with a few things which made me raise my eyebrows.
"Brake caliper bolts tie wire" Basically he reckon's the holes in the head of the top caliper bolts is for a wire to go through the bolt and wrap around the stub axle to stop the bolt from falling out. Interesting. : If i'm not mistaken that hole is for a wire, but it's to hang up the calipers when you remove them so they're not hanging off the brake line. The 17 x 8 mags wheels i have on the car are too large, there isn't enough clearance between the inside of the rim and the top ball joint. Plus apparently they're 2 inches larger than standard which makes them too big. My LPG system doesn't have a "Gas box safety switch" so the entire system needs to be rewired to fit one. Conveniently this bloke just happens to be a R/W tester and LPG installer. What i can say is the bloke who fitted my S/H motor last month said my gas safety switch was faulty, and that's why my car wasn't switching onto gas properly. I watched him reconnecting the safety switch myself, so i'm pretty damn certain my car has one. Tester also says that my tank is out of date. I had it retested 2 years ago, and fair enough the idiots didn't stamp my tank they just gave me a certificate from the tester. But the certificate still has the tank serial No. etc to prove it. Testers says its rubbish though. Conveniently he can retest my tank for $220. Alignment is out. Curious. Tyre wear so far is spot on, i also work at a tyre place doing wheel alignments and mine is schmicko. He says my Whiteline rear sway bar kits needs to be removed or engineered. I have no idea if this is true or not, but at this point i can't tell what's BS and what isn't. Of course just to do me a favour, they said they would keep my test off the books to give me longer than 7 days to fix it all. What the??? I'm no mechanic so i don't have a clue if they've picked legitimate things or not, but this test stinks like crap to me : |
25-04-2008, 10:34 AM | #2 | ||
Blue Power enhanced
not sure if your allowed but incase your in melb, i and im sure others would like to know who this dodgy guy is.
As far as the r/w goes i thought you get a month to fix... or is that a month that it's valid for after it's fixed.... hmm not sure, and as far as wheels go, in melb you can have 2'' larger just no more than 2''. Stay away from him mate. DODGY DODGY DODGY
QIKSUV vic plates for sale also selling my C.A.P.A tune box |
25-04-2008, 10:37 AM | #3 | ||
Depending on which state you are in.
Brake caliper bolts tie wire is correct Rims, 1" larger in width and diameter is permitted from factory- what was the XR option from factory, 15" or 16"? Other than that a second opinion would be my suggestion. |
25-04-2008, 10:37 AM | #4 | ||
Car Newbie
Sounds Dodgey to me mate, If your in Melb, Go through the RACV or something..
2005 5-speed Manual Shockwave BA MKII XR6
XR6T Snorkel : F6 Intake : BA GT Catback Exhaust : K&N Air Filter www.bseries.com.au/subjimbos_xr6 |
25-04-2008, 10:44 AM | #5 | ||||||
Its to lock the bolt. Quote:
The law is + 1" from the factory wheel spec for width OR diameter.... Quote:
If he let all that go it would be dodgey, and he could loose his licence or face prosecution if something happened to your car and he let it go... good to see someone do a proper R/W.
335 S/C GT: The new KING of Australian made performance cars.. Last edited by 4Vman; 25-04-2008 at 10:52 AM. |
25-04-2008, 10:53 AM | #6 | ||
All sounds pretty legit to me too.
25-04-2008, 11:21 AM | #7 | ||
I dont know about other states but in South Oz we allowed to go 2" over factory wheel specs also have done quite a few brake repairs and have never come across Brake caliper bolts tie wires
25-04-2008, 11:29 AM | #8 | |||
Regulator
The Roadworthy Certificate is valid for 30 days upon receiving one.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
25-04-2008, 12:11 PM | #9 | ||
Like i said i'm not a mechanic so don't know any better, just certainly felt like i was been taken for a ride. Cheers for the advice guys. Certainly correct in saying that people shouldn't be doing dodgy roadworthy's, but for a consumer there's really no readily available source of information to know if they've done the right job. Which is why i mentioned it here, i figured it would be sorted out fairly quickly.
Will take it back to where i had the tank originally tested and get them to sort that out on Monday. Pretty poor form charging someone $230 for a tank test and not even stamping it. Bit of wire on a bolt and removing the sway bar and she should just about be right. |
25-04-2008, 12:19 PM | #10 | |||
Back to Le Frenchy
He's wrong about the wheels. The difference is not iin the actual size of the rim but in rolling diameter so a 17" wheel does not have a rolling diameter greater than 1.25" (that's what Vicroads stated) making it legal.
Personally I'd find a different tester, what area are you in?
25-04-2008, 12:21 PM | #11 | ||
Pushrodosaurus Rex
in WA you are allowed 2" in diameter, and iirc it doesnt matter how wide your wheels are provided that they sit in line with or inside the guards.
25-04-2008, 12:32 PM | #12 | |||
335 S/C GT: The new KING of Australian made performance cars.. |
25-04-2008, 12:48 PM | #13 | ||||
Back to Le Frenchy
25-04-2008, 12:52 PM | #14 | ||
I'm in Ballarat, didn't have the test done by my regular bloke because i wanted it done ASAP and he was busy.. As far as the wheels and tyres go I'm running 235/45/17 tyres which are 643.3mm diameter, the stock wheels 205/65/15 are 647.5mm. So mine are 4.2mm smaller. Rims are just the Koya XR which is a pre-AU rim and it all fits nicely under the gaurds.
25-04-2008, 01:02 PM | #15 | ||||
Back to Le Frenchy
25-04-2008, 01:05 PM | #16 | ||
What's green is gold
I wouldnt say dodgy, Just very, very picky! Which at the end of the day is a good thing, I have been burnt by the dodgy RW/Canary duo.
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
25-04-2008, 01:53 PM | #17 | |||
WRX terrorist
You cannot go over 1" wider though.
: MY-03 STi :
25-04-2008, 04:55 PM | #18 | ||
guys - straight from vic roads website :
vic roads - mods guide section 8: no engineering required for : diameter: +15mm max diameter of rim+tyre of largest offered for that model ( -15mm of smallest factory offereing for that model) width : +25mm over widest RIM offered by factory http://www.vicroads.vic.gov.au/NR/rd...340/0/VSI8.pdf brett |
25-04-2008, 05:50 PM | #19 | ||
lol 25mm = .984 inches. XG only came with 15 x 6 rims so anything wider than 6.984 isn't road worthy.
25-04-2008, 07:00 PM | #20 | |||
25-04-2008, 08:11 PM | #21 | ||
does a freind\family member have a x series-eseries ford with legal tyres with standard rims?? if so i'd jack the sucker up and swap them for a few days lol.
not a good idea but ive done it lol or buy some stockies where in ballarat did you go? ive had the last few done in delacombe. the bloke i use can be a little strict but ive found him fair on most things |
25-04-2008, 09:44 PM | #22 | |||
25-04-2008, 10:08 PM | #23 | ||
Just a bogan VF SS driver
u didnt go to hansens tyre and mechanical in emerald qld did u
Just your typical Holden Driver |
25-04-2008, 10:13 PM | #24 | |||
XP Coupe
26-04-2008, 12:12 AM | #25 | ||
rocknrolla
they picked the lack of tie wire on my p6's brake calipers when i was getting it off defect. it really is rubbish though, 99% of the cars on the road have bolts of smaller diameter and no tie wire provisions. brake calipers dont come loose unless they were never tightened properly in the first place!
ps glad we dont have RWC in SA.
1979 P6 LTD 383c
1970 ZC Fairlane 500 351w 1964 XM Falcon Deluxe 200ci |
26-04-2008, 06:29 AM | #26 | |||
LIFELONG DJR SUPPORTER
26-04-2008, 07:03 AM | #27 | |||
Regular Schmuck
26-04-2008, 07:37 AM | #28 | ||
rocknrolla
funnily enough I havnt seen old corollas running out of brakes ploughing into bus stops on a weekly basis because we dont have a RWC system. how often does an accident involve mechanical failure? the percentage is insignificant.
as far as im concerned its just another money making/paperwork exercise that penalises people who have several cars. its bad enough paying registration and insurance on each individual car despite the fact i can only drive one at a time.
1979 P6 LTD 383c
26-04-2008, 07:44 AM | #29 | |||
/////////////////////////////////////////////////////////////////// AND there you have it in one, not tightened properly but with tie wire = no having the bolt work its way loose while family driving down the Hi-way at 110kmh, as for revenue raising fees ,well thats a whole new topic i guess.
Hervey Bay QLD Great trades recently- GILMORE BOSSYONBIKE |
26-04-2008, 07:46 AM | #30 | ||
O yea its money making, I used to make a killing spendign 1/2 an hour doung a road worthy at a wopping 23.00 (State gvt regulated price back then) when my normal hourly charge out price was $75.00 an hour
some of the things I saw you would not beleive like the ZH fairlane where the owner had used Bunnings grade 3/8 bolts to hold the steerign box on, Y? well becasue the thread was stuffed when he replaced the leaking power steer box with a brand new 2nd hand one and 3/8 was all they had at the hardwhere stoor. thats just 1 that springs to mind
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
