Old 18-04-2008, 12:16 AM   #1
stockNAfairlane
Default Engine conversion workshops in WA.
Does anybody know any workshops in WA that can do GOOD engine conversions?
The car is my 83 500SEC Mercedes.
I'm thinking LS1 or similar power engine in place of its stock 5.0 v8. I want it powerful, reliable and fairly unique.
I have around 10k all up to play with.
Any ideas who to call and talk to or which workshops to visit? Or any advice?
Cheers guys
stockNAfairlane is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 05:07 PM   #2
Green X
well first up you would need to see if anybody makes a bell housing to suite that type of conversion cause i doubt the merc gearbox and Chev engine are going to join up without one.
wouldn't hurt to call around the Proformance type workshops, even try some of the site sponsors for advice.
FPV GS ute 5.0 S/C
Twin 3-inch, pacemaker headers
Green X is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2008, 12:45 PM   #3
crusher
Dirty ute club member
crusher's Avatar
Or you could replace the merc gearbox with the one attached to the LS1 if it isnt too big.
Im pretty sure the swap has been done before. A google search might help. I know there are quite a few jag chev swaps around so maybe there is a kit or something like those ones. Have a look at the rod shop site. They may have something.
And for 10k you might be better off doing it yourself? The ls1's are still a few grand plus a few more if you want to do heads/cam and a tune.
Would be a fun project thats for sure. Hear a big beefy v8 and see an old merc go past. would confuse alot of ricers!
2000 AU2 XLS Daily
1992 Toyota Celsior: 4ltr quad cam goodness
UZN106 Hilux: Absolute mongrel bitsa also with 4ltr quad cam goodness...Forced induction in the planning
crusher is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 01:30 PM   #4
Ridin-High
http://holmart.com.au/online/prod1823.htm
HSV LS2 Motor ENGINE COMES COMPLETE: MINUS STARTER,ALTERNATOR P/S PUMP AND A/C COMPRESSOR $4650
http://holmart.com.au/online/prod1906.htm
VZ V8 4L65E AUTO TRANSMISSION
COMPLETE WITH TORQUE CONVERTER, LIMITED NUMBER AVAILABLE $1799
"I've got 2 Blow off valves, their for the chicks bro"
Ps. Yes i have used the search button mum....
Ridin-High is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 01:46 PM   #5
Mont5.0
Mont5.0's Avatar
You will get the running gear for under $10,000- fitting and converting will cost some more. budget may be around 15,000 +
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 05:53 PM   #6
stockNAfairlane
Damn, was hoping to keep it under 10, don't mind using a low kay second hand ls1. But gearbox i want new or very newish.
Thanks for the pointers
Old 21-04-2008, 11:16 PM   #7
Tony xa
Streetrides panel & paint
Tony xa's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Tonys qualified advice on paint and panel is always very good
Your budget i sway off this kind of thing engine ,gbox and wiring will hit the 10k alone and that is without any labour and a couple of grand worth of problems that are going to come up .
Tony xa is offline   Reply With Quote Multi-Quote with this Post
