26-03-2008, 11:59 AM | #1 | ||
Did a quick search and can't find similar discussion so...
OK, most people have a beef with people using fog lights in clear conditions, but today Sydney was particulary foggy for the morning commute, yet hardly anyone with fog lights used them, worse, most people still drove with NO lights on. I have always had front and rear fogs on all my cars as I have lived in some fog prone areas. I even had them on my old EF and EL's (haven't had a chance to put them on the NC yet though). They are always used, and turned off pretty much the second that they are needed or not. Anyway, its bad that people use them when they shouldn't, but not to use them when they should.... then what is the point?
93 NC2 Fairlane Ghia Sportsman. Standard Tickford 162kw engine and touring suspension, factory LTD trim option plus EF Ghia wheels. Other rides: Range Rover Sport, Mini Cooper Chilli Cabrio |
26-03-2008, 12:03 PM | #2 | |||
Cheers, Sam. |
26-03-2008, 12:14 PM | #3 | ||
Bringing the Spartan back
Because most Australian cars don't have "Fog lights"!
True fog lights have a high intensity rearwards red light that is visable to following drivers. No front mounted Driving light will enable you to see through fog, infact almost any light makes it harder to see
East Coast Suspensions Road - Race - Performance & Prestige Car Service BOSS 5.4L Silicon hose kits for sale BA/BF FPV parts for sale The only negative thing in your life should be camber Blue Power Racing Enhanced Chris & Craig - Thanks! |
26-03-2008, 12:37 PM | #4 | ||
Grum, a lot of new cars only have front 'fog' lights, only a few do have the rear ones. The ARR's do recognise both front and rear, although most manufacturers do claim that front lights are fog lights (so they don't have to be wired to high beam circuit), even though they aren't. The more worthwhile rear ones are almost NEVER used in fog. Thing is though, that they are the only thing that makes your car visable to following drivers, tail lights are useless and hazards only marginally better. If you are keen to avoid a rear shunt, like we are, these are invaluable.
I disagree with front fog lights not assisting though. Correctly fitted and used lights (very rare) both white and amber, can make a HUGE difference to the regular foggy conditions driver. I know from experience and swear by them. They light the road much lower and shallower than standard lights because the fog usually floats just above the road. This gives correct intensity and angled lights a window of opportunity to light this limited area. Normal headlights, and incorrectly aligned lower front lights (such as most Commodores) just reflect back the light in the fog which is why you switch off main beam lights with proper fogs. The BA XR ones aren't actually too bad though in true heavy fog.
26-03-2008, 01:21 PM | #5 | |||
this is only 1/2 right yes white light tends to reflect back off fog but when mounted low (as fog lights should be) they will project the light further into the fog as it is generally thinner the lower you go
[SIGPIC][/SIGPIC]
26-03-2008, 01:21 PM | #6 | ||
Have Boost, will use it..
The ones that are standard in most of the Falcon range ie XR range are driving lights, not fog light.
26-03-2008, 01:22 PM | #7 | ||
BA lights with stock bulbs are hopeless in real fog - I'm talking for at the Farm (high Altitude) where you dont get out of the car to take a leak... otherwise you might get lost
26-03-2008, 01:27 PM | #8 | ||
The one and only
The lights are for "Mark Scaife wannabe's" hence why commodore drivers use them a lot.
They have zero practical use (I don't care others argue against this)
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
26-03-2008, 01:31 PM | #9 | |||
26-03-2008, 01:35 PM | #10 | |||
Sounds like where my farm was (1000m alt)!
26-03-2008, 02:26 PM | #11 | |||
26-03-2008, 02:50 PM | #12 | ||
King of the Fairy's.
Can anyone give me any more info on the rear fog light? Any pictures of where they are usually mounted?
I wouldn't be a huge fan of my taillights in a fog and to avoid an unwanted accident would be great.
26-03-2008, 03:14 PM | #13 | ||
Hey Pinch, not sure what sort of search you did but there are quite a few threads/posts on this and some of them got a bit heated but no probs. Seems many people think that they help at night but that doesnt gel with me as they only light up a very short distance in front of the car. That doesnt give any time to react no matter what. The Ford fraturnity say only Commonwhore drivers use them in the daytime (**** factor) but i notice some Ford drivers use them too albeit nowhere near as many. Law says you cant use unless in adverse weather conditions and a couple of people on here have been booked or warned for using them in daytime. KEEPLEFT can quote chapter and verse the ins and outs and the rules/laws/regulations/specifications of said devices. Good luck.
igodabigblackshinycar and I relented and allowed a BMW into the garage. |
26-03-2008, 06:37 PM | #14 | ||
Deesun - I thought there would be heaps too but I did a quick search for 'fog light' with the first two results pages not showing much relevance. I should have been more specific I guess.
Airmon - Aftermarket rear fogs are pretty hard to find. I got mine years ago from a stall under the escalators at Paddy's Haymarket (Sydney). Not sure if they are still there or if they still sell them. They were about $20 at the time. Had a quick look and not much doing on Ebay for them either. I mounted mine under the bumper, not really noticable unless turned on. Just two screws and a bit of wire and a switch I wired to the park circuit. The cars that come with them have them either as one or two seperate lights in the bumper (like Excels) or one or two lights within the rear light cluster itself (BMW). Many of the new ones have one reverse light in one side and the red rear fog in the other (like VW New Beetle).
26-03-2008, 06:44 PM | #15 | ||
Mopar! But Own F6's..
In my FPV manual, they arent fog lights, they are called "driving lights"..
F6 TYPHOON FPV 335 GT |
26-03-2008, 06:50 PM | #16 | ||
Zoom Zoom
All Fiesta, Focus and Mondeo models come with rear fog lights standard as these are required in Europe for all vehicles - hence the European models we get here have them by default. The front lights on all those above vehicles when fitted are actually fog lights and not driving lights.
I believe the driving lights on Falcon and Territory are more for practical night driving in the country and on back highways when out bush, to permit better coverage of road edges and perhaps assist in fog when possible. There's certainly no requirement for front or rear fogs in Australia and as a result the Aussie versions seem to be more a night-driving light than anything. Either way, both see no real need in street-light equipped cities and towns.
2012 Mazda3 MPS
26-03-2008, 06:50 PM | #17 | ||
people are stupid. question answered!
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
26-03-2008, 07:14 PM | #18 | |||
this would be the rear fogs, in most Euro (or Euro built like RHD Jeeps & Chryslers) cars they are incorporated into the taillight housing. they're the bottom high intensity red light, sorry about the crap photo. i havn't seen the other ones though, that you can mount? |
26-03-2008, 07:50 PM | #19 | |||
People just like to whinge The lights in question serve no purpose during the day or in fog conditions and are of very limited use at night as they shine so close to the front of the vehicle anyway. |
26-03-2008, 08:05 PM | #20 | ||
Clevo Mafia Inc.
