Old 28-02-2008, 05:16 PM   #1
REDAUXR6II
REDAUXR6II's Avatar
Default New Radiator
Hey All,
I have to replace my radiator as it has corroded down one side, has anyone had much experience with PWR radiators?
Is there any benefit from fitting them? in terms of better cooling\lasting longer etc.
Or should I just buy one from Ebay, I got quoted $942 from PBR for one.
Thoughts?
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 07:20 PM   #2
matt9889
new kid
matt9889's Avatar
i brought a copper core radiator on ebay recently for $235 delivered. its got a 12 month warranty i think and its a bit thicker as well.
matt9889 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 07:30 PM   #3
blackers10
blackers10's Avatar
shoot a PM thru to BLUEPRINT he will point you in the right direction
i beleive he highly reccomends ADRAD radiators as they are australian made etc and arnt stupidly expensive and a GREAT quality
Old 28-02-2008, 07:32 PM   #4
REDAUXR6II
REDAUXR6II's Avatar
Yeah I am leaning toward the PWR as I want to eventually get into track work with it.
Old 28-02-2008, 07:42 PM   #5
JMO
JMO's Avatar
I second the ADRAD copper core.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 08:09 PM   #6
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Why the PWR One .. $945 for a Brand Name .. I Believe id Go with Blueprint , he is the Resident Radiator Guy and Pick the ADRAD one ..
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 08:13 PM   #7
REDAUXR6II
REDAUXR6II's Avatar
so is the ADRAD one better than the PWR?
The reason I mentioned the PWR one is that I am thinking about getting into track days and i wanted a good setup
Old 28-02-2008, 08:40 PM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Your Not running a leMans Spec Race Car .. the ADRAD one will be fine and do the Job just as Effiecently as the PWR one ..
AU2PWR
Old 28-02-2008, 08:52 PM   #9
REDAUXR6II
REDAUXR6II's Avatar
ok thanks for the info, I will look at getting the ADRAD one.
Old 28-02-2008, 09:01 PM   #10
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
No Worries .. By all means Grab the PWR one , but The ADRAD will do the Same and Leave you $500 to spend on more Stuff !
AU2PWR
Old 28-02-2008, 09:07 PM   #11
REDAUXR6II
REDAUXR6II's Avatar
is there much difference between the brands? such as build quality, performance, durability?
the only reason I ask this is that the mechanic that I go to for all of my performance mods, was saying that if I am interested in going down the turbo track (sometime next year) that I should invest in the PWR, but if it isn't any better than a normal one ill get the normal one.
Thoughts?
Old 28-02-2008, 09:12 PM   #12
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Nah .. The Intercooler will handle the Heat from the Turbo , thats not a Factor
AU2PWR
Old 28-02-2008, 09:14 PM   #13
REDAUXR6II
REDAUXR6II's Avatar
ok, now its starting to make some sense, so do I get the ADRAD one or the PWR one?
oh and do you know what sort of money the ADRAD one is?
as far as I can see the PWR one is made from supposed high quality Aluminium and the ADRAD one is made from imported parts (has made with imported parts on the website)
Old 28-02-2008, 09:33 PM   #14
JMO
JMO's Avatar
I don't know about imported parts, but you have the choice between copper and aluminium with the ADRAD. If I remember correctly it was only about $200 for the copper item and only a few dollars less for the aluminium.
EDIT: I'm by no means an expert, but i'd say the difference between the two would be that the aluminium is lighter but the copper conducts better.
Old 28-02-2008, 09:34 PM   #15
REDAUXR6II
REDAUXR6II's Avatar
ah ok, thats not to bad I will give them a call tomorrow and see what they say. Thanks for the info people.
Old 28-02-2008, 11:34 PM   #16
blackers10
blackers10's Avatar
why not shoot a PM off to BLUEPRINT
he will be more than happy to assist you mate!!
and you dont want to OVER COOL your motor on the street either.. cause more trouble than its worth i think!
but he definatly reccomended me the ADRAD gear just cant put my finger on which type in particular he said
Old 29-02-2008, 07:27 AM   #17
Mechan1k
Mechan1k's Avatar
I went through the fun of getting a radiator for the work ute that could handle heavy load in the middle of summer without the needle creeping towards H.
In the end I went with the ADRAD twin core copper radiator ... with the heavy duty/towing internal transcooler (I also have an external cooler as well). $275 inc. GST.
Twice the thickness of standard ... does the job perfectly.
Although in winter on the highway ... I watch the temp needle plummet towards C.
Old 29-02-2008, 08:13 AM   #18
REDAUXR6II
REDAUXR6II's Avatar
by the sounds of things the ADRAD one is the way to go, where do you buy them from?
Old 29-02-2008, 08:15 AM   #19
Mechan1k
Mechan1k's Avatar
I purchased mine direct from NatRad ... but any mechanic can get them ordered direct from ADRAD ... well I am pretty sure they can.
Old 29-02-2008, 08:23 AM   #20
REDAUXR6II
REDAUXR6II's Avatar
Cheers, I will get one of them and put the money toward something else.
Old 29-02-2008, 09:09 AM   #21
InfernoSR
Sales Representative
InfernoSR's Avatar
You can get an ADRAD 3row radiator... and from my sources, they even have an Brass Tank version... food for thought... and PWR... their street radiators simply arent worth the cost. They do however make some very high quality intercoolers and HEAVY raced based radiators.
I'd go the 2 row for everyday use and you'll be laughing and the quality difference over std factory... but if you want something a bit tougher for the strip, ask around for the brass tank, 3 row assembly...
Old 29-02-2008, 09:28 AM   #22
REDAUXR6II
REDAUXR6II's Avatar
I didn't know PWR did normal street stuff? I thought the $942 I got quoted was for the race series stuff?
Anyway I have emailed ADRAD for some more info and prices.
Old 29-02-2008, 09:52 AM   #23
InfernoSR
InfernoSR's Avatar
The gear you are talking about is what i'd classify as Street and occasional Strip...
Old 29-02-2008, 09:56 AM   #24
REDAUXR6II
REDAUXR6II's Avatar
expensive stuff, yeah I think I will leave te PWR stuff to someone else.
Old 29-02-2008, 11:03 AM   #25
InfernoSR
InfernoSR's Avatar
LOL... good choice
