Old 29-01-2008, 10:19 PM   #1
KW XRT
KW XRT's Avatar
Default How to get 60ft faster with auto
Auto XR6 T
Got the tune box in and the dyno says 217 RWKW on the 8 so the 10 should be more.Ran the 10 and late in the day ran the 8 and it was 2 tenths slower than the 10.
Ambiant 37 track 50 {guess
5th and last pass at 17 10 2nd pass 1510 1/8th 144.233
1/8th 9.623
Best et 14.528 1/4 14.802
1/8th 9.465 Mph 91/147
60 ft 2.332
MPH 96 .360 155
Like the MPH but 60ft is slow any idea's car was stalled to 1800 and floored {didn't want to break it.
cheers
Ambrose driving in Nascar and joining RPM Murphy somewhere in the V8'S.
XR6 Turbo.Championship winner.
KW XRT is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2008, 11:11 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
37deg amiant won't help at all, even though 96mph seems SLOW for 217rwkw.
was it wheelspining off the line? If not, stall it up some more. A mate was seeing 2.10's from stock BA Xr6T's at AIR before it was shut down (stock 18" dunlops @ 38psi).
Old 30-01-2008, 01:15 PM   #3
KW XRT
KW XRT's Avatar
No wheel spin that I can detect dropped the tyres down to 29 lbs.I agree seems slow doesn't it.Especially as the 10 feels stronger I recon at least 10 RWKW.
The car pulls really hard once over 3 k and is actually catching cars in 13sec bracket but gives away too much of a head start.
I feel as though there is no boost the guage reads "0" when stalled and can't work out how to get it on to boost for the take off.It was the first time playing though.
Took me 4 runs to beat my old sixpack {E38 made me laugh a bit.
cheers for the time welshy
Old 30-01-2008, 01:18 PM   #4
KW XRT
KW XRT's Avatar
double up lol
Old 02-02-2008, 02:56 AM   #5
Falc'man
You dig, we stick!
Falc'man's Avatar
Hi mate.
Is your car a BA or BF? (Four speed or ZF?)
Do you have custom tunes or just the generics? It sounds like you have a generic tune with nothing done to remove torque tags... If so, get a custom tune.
What was the humidity like when you had the runs? Your times may not reflect how quick it is if the conditions weren't favourable... but as you say, if others had way better 60' times then yes, something ain't right.
Also, don't deflate your tyres if you're not getting wheelspin (at the desired stall rpm), pump them up instead.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2008, 11:45 AM   #6
ebxr8240
Performance moderator
ebxr8240's Avatar
I'd spool it up at top of tree with handbrake on and left foot on brakes pedal...
Control by throttle... Time spools turbo....
Release hand brake etc when second from bottom light goes out....
You auto guy have it soooo easy !!!!
Daily driver GTE FG..
Old 02-02-2008, 12:39 PM   #7
F6BF
Originally Posted by Falc'man
Hi mate.
Like Falc'man has mentioned custom tune with torque management adjusted u can spool the turbo to more boost off the line without the throttle closing, this should improve your 60ft
FG F6 sedan
Stock 12.29 @ 113mph on mt et street tyres
XR6T Sprint winter white
XR8 Sprint winter white
GTF Octane manual
FS: ZF 6 sp trans & converter out of stock BF mk2 typhoon
F6BF is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2008, 01:11 PM   #8
Stav
Smile
Stav's Avatar
Auto XR6 T
1/8th 9.623
60 ft 2.332
MPH 96 .360 155
cheers
96 mph means that on those runs the car developed around 150 to 160 rwkws..It does not indicate 217 killowatts.14.5 is not a bad time considering the 60 footer.I thinjk you should invest in a torque converter with an extra 500 rpm stall speed than standard and watch the times tumble.
Ther other problem is the tune.It obviously has not provided you with the torque down low to get it moving much faster. I would front the tuner and ask the question why? Tuners are only human too.
Old 04-02-2008, 12:21 AM   #9
KW XRT
KW XRT's Avatar
Hi mate.
Thanks for the responses guys.
Car is 2004 BA with 4 speed auto.Not sure on humidity but it was bloody hot.
Generic tune.Car seems slow out the whole with no chance of wheel spin.I put BF phoon plugs in and regapped them to .8 mill.Car ran well and apart from hunting after start up it ran fine.Like I said stalled it to about 1800 didn't feel as anymore was warranted.Car was dyno'd with 217 RWKW from the 8LB.
Thought of a high stall B/Inlaw recons he can get 2500 easy for me but would want it out after so that's why I've baulked at it.
The third or fourth run was a bye and so I was able to hear this huge 2nd gear wheel spin and a chirp in 3rd.For those that arn't aware the tune box ups line pressure to firm up the shifts.Anything above 3000 the car realy pulls hard.Hopes of smacking my mates 265 ute {13.5 goooooone : untill I get some more HP.Lookes like a custom tune comming up.
I was trying to chyange at bit over 5k but thought it better change where maximum torque is but I didn't get torque figures from the dyno.What's your thoughts.
By the numbers
Best 60 FT 2.296
Best 1/8 9.465 fastes 1/8 89.641 MPH 144 KPH {faster than a 12.3 torana
Best 14.518
Best MPH 96.774/ KPH_155.710
cheers
Old 04-02-2008, 04:32 PM   #10
Falc'man
You dig, we stick!
Falc'man's Avatar
Yes, you definitely need a custom tune mate if you want that better take off. From there, you can decide if you should get a stall convertor. And yes, use the torque of the motor, no need to use high rpm if tuner has tuned it to make good midrange.
Cheers.
Old 04-02-2008, 06:00 PM   #11
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
By the numbers
Best 60 FT 2.296
Best 14.518
cheers
Something is not right here, 89mph to half track and 96mph at the finish doest not add up at all, thats sort of mph at the 1/8 mark you would need alot more than 217rwkw and/or well into the 1.7-1.6 60ft's to achieve 89mph (the lower your 60ft your half track mph will go up).
With a time of 9.4 to half track and a 2.3 60ft your mph should around 77-78mph.
Also mate you should be able to achieve a 2.1 60ft with a std stall (and take into account every .1 off your 60ft take .2 off at the finish) I would be trying to achieve that before you go to a high stall as it will get harder with the high stall, be more agressive off the line and you will have to learn how to drive your car all over again. If you just jump ahead without learning the basics you will find it very difficult down the line and not understand why things are happening.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2008, 03:13 PM   #12
KW XRT
KW XRT's Avatar
Yea Don't know what happened with those times.That run felt fast {89 MPH 1/8 mile the car went and felt fast {overcast so bolted for the start line good drive 1st and second but car went from 2nd to 4th for some stupid reason {must have lifted foot or double clicked the sports shift but the 1/4 mile felt way faster than 14.8
cheers
Old 06-02-2008, 03:42 PM   #13
xwgasaxe
under new management
xwgasaxe's Avatar
I decided to read the owners manual from the T once and it indicated that if the engine oil temp got too high then torque would be reduced untill temp drops below a determined level.
Maybe get a oil cooler like the Typhoon.
XW tarmac rally car, 3/4 race cam, NGK spark plugs
xwgasaxe is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2008, 11:21 AM   #14
LTD351T
LTD351T's Avatar
What does the car run like in the auto shift mode? Might feel slower but could be faster? factory models I heard were faster when left in auto.
Can you select 2nd gear while stationary @WOT??? Being able to load up in high gear will spool turbo much easier, and no creeping.
www.TURBO351.com
www.cletusracin.com
2V 351, 747rwhp @18 psi on LPG
LTD351T is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2008, 12:13 PM   #15
66 coupe
around the place
66 coupe's Avatar
with a custom shift kit you can.... also try removing the brake fuse, that way the ecu doesnt know your on the brakes
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2008, 04:56 PM   #16
KW XRT
KW XRT's Avatar
Known about this for some time and it surfaced on the dyno but only after the 3rd run,car now runs nulon full synthetic and temp seems even cooler than before {which also could pose a problem lol.Car didn't seem to be getting hot and was left to cool after every run.
66 coupe
with a custom shift kit you can.... also try removing the brake fuse, that way the ecu doesnt know your on the brakes.
Nice thought there 66 you might be onto something as there does seem to be a computer protection thing.Couple of seconds out it goes like a scolded cat.Shame there wasn't more time late to experiment but I ran out of opposition.Few commadores got put on the trailer early.
cheers
