Old 20-11-2007, 06:54 PM   #1
ALEXR8
Default Au Seat Question
Just Wondering If And Body Knows If The Au Seat Frame Is Similar To The Ba Frame At All? Why I Ask This Is Because I Have A Set Of Ba Gtp Seat Foams That I Want To Adapt To The Au Frame If Possible? Any Info Would Be Great. Thanks
ALEXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 07:04 PM   #2
Burley
CRE.87V
no mate frames are completely different...the au has a pull out base frame....the ba back or squab unbolts off the base frame which is incorporated with the seat rail and frame....u only have the foams??? or the covers as well??? if just foam....why not just build up the outter wing panels an inch thats wat i done to my xr6..hope it helps
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 10:50 PM   #3
chief
FTF Club Moderator
chief's Avatar
If you have the foams surely you can glue them onto the existing foam for the AU? Then get the seats retrimmed.
Albert Einstein:
Fords in the Park 2010
Old 21-11-2007, 06:13 PM   #4
Burley
CRE.87V
na frames are different...wish it was true...the only thing u can do is the build up the existing a seats....foams are completely diff to
