Old 05-11-2007, 03:50 PM   #1
ford-88
ford-88
Default no oil pressure
hey I've got my dash in that digital mode an its showing up no oil pressure. when i first put in digital mode a while back it worked. anyone got any ideas to wats happened
thanks
ford-88 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 06:49 PM   #2
speedfreak
i miss my torana!
speedfreak's Avatar
oil pump is dead or you have no oil
speedfreak is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 09:03 PM   #3
ford-88
ford-88
I've checked the oil its all good. how do you check if the pump has gone
Old 06-11-2007, 08:37 PM   #4
speedfreak
i miss my torana!
speedfreak's Avatar
ummm take off your oil cap wile the engines running and see if oils comming to the top? just guessing never tryed it but it sounds like it would work lol
Old 07-11-2007, 08:50 AM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
also check the Vaccuum Thingy on the Top of the rocker cover is on properly , and its not producing a Vaccuum Leak
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2007, 10:17 AM   #6
atec77
thanks
You might reset the dash , or install a real mechanical gauge as the sender might have kaked
Old 07-11-2007, 02:46 PM   #7
Mechan1k
Mechan1k's Avatar
OK .... if you are in the diagnostic mode for the dash ... if the oil pressure section is reading 0 ... it means that it is OK.
eg:
0 = normal
1 = failed condition / warning light on
So you have no issues.
Old 08-11-2007, 01:34 PM   #8
ford-88
ford-88
in diagnostic mode it use to show what a would guess is the oil pressure use to change readings all the time
