Old 29-10-2007, 09:36 PM   #1
ROOSTA
DFDFDF
ROOSTA's Avatar
Default Help please i beg you!!!
Hello,
I have been on wat is seeming like a wild goose chase for almost a month.. I am chasing a diagram with the AU vacuum hose layouts from a gregory's or similar..
Surely some one out there can scan it up and email or post it up for me PRETTY PLEASE..
I am in desperate need..
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 11:09 PM   #2
ronwest
All Bran = Regular Member
There's no specific section in my Gregorys for "vacuum hoses" or "hoses vacuum".
The only general info I could find in a quick look merely says to make sure that the vacuum hose connections are tight and the hoses aren't split etc.
Sorry...
Old 29-10-2007, 11:55 PM   #3
ROOSTA
DFDFDF
ROOSTA's Avatar
Ah that sucks.. No pun intended.. LOL..
I have been trying to nut this one off for a while and i am so close.. just need to know which colours go where on the back of the zone selector..
Cheers,
Nik
Old 30-10-2007, 12:25 AM   #4
ronwest
Is the "zone selector" part of the aircon?
If so there's a few diagrams before and after this one:-
http://www.fordforums.com.au/photos/...=22395&cat=697
Old 30-10-2007, 01:37 AM   #5
ROOSTA
DFDFDF
ROOSTA's Avatar
Yer.. By zone selector i mean the dial which allows you to select screen - feet - face - fresh - recirc.. I have found all of those and have tried my best to work it out on paper but i need to know where each of the colour feeder tubes goes on the back of the dial section..
Maybe if i describe wat i am doing it will help.. I have retro fitted an AU2 aircon controller into my ED and need to work out where to put each of my ED vac lines.. But without having a AU vac loom to look at i dunno where each line goes on the back of the control.. Dunno if that helps..
Cheers,
Nik
Old 30-10-2007, 02:51 AM   #6
ronwest
Ok, there is an aircon vacuum hose diagram in my Gregorys.
I take it yours does not have climate control?
Anyhoo, my scanner isn't hooked up at the mo and it's getting late, so I'll get it organised for tomorrow night .... unless someone else can scan and post?
Old 30-10-2007, 08:14 AM   #7
Chippar
The Ancient Warrior
Chippar's Avatar
deleted by chippitydip....can't upload pic.
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2007, 08:39 AM   #8
Chippar
The Ancient Warrior
Chippar's Avatar
I'll have another go at posting the diagram...It's for the system without climate control, copied from the Gregorys manual.
Old 30-10-2007, 01:22 PM   #9
ROOSTA
DFDFDF
ROOSTA's Avatar
Ok.. Getting closer thanks guys.. I think i will just have to go to the wreckers to see the actual plug.. Grr.. Its frustrating me.. LOL..
Thanks again guys..
Cheers,
Nik
