Old 24-10-2007, 10:21 PM   #1
RachsEa
RachsEa's Avatar
Question How to tell the diffrence between a 351 and a 302 Clevland
Heys everyone,
I recently just brought a ZJ Fairlane its a 1979 model, and the guy who I brought it off is unsure wheather its a 351 or a 302 Clev, and I am unsure myself, Is there something on the motor that i can look at to see what it is, Besides looking at the crank, any1 that can help me would be good,
Thanks Rach
: 1979 ZJ Fairlane, Red
351 Cleveland, FMX, LSD, Lowered , Sittin on 12 slotters :togo: Heaps of Improvements to come Finally changed the interior from cream to GREY looks hot as..: :
And My New Car..
1979 XD Fairmont
351 Clev, Low 17 Centrelines Auto B&M shifter Red, Sexy daily, Well I think so :
RachsEa is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2007, 10:24 PM   #2
Barry_v
rocknrolla
Barry_v's Avatar
not really, only foolproof way to tell is to measure the stroke. never tried to do it myself, but ive heard people try and do it with a coathanger down the spark plug hole. 351 should be 3.5" and 302 is 3"
1979 P6 LTD 383c
1970 ZC Fairlane 500 351w
1964 XM Falcon Deluxe 200ci
Barry_v is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2007, 10:50 PM   #3
ebxr8240
Performance moderator
ebxr8240's Avatar
Where does the top radiator hose go to on engine???
If it goes to head its a Windsor. To block Clevo..
Daily driver GTE FG..
Old 24-10-2007, 10:54 PM   #4
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
I think she knows its a clevo, its the CID she's after.
If the engine number on the block matches the compliance plate it is original engine. Simply get the engine code and check it.
T=351, P=302 and i think there is a B code for NSW 302's
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2007, 10:58 PM   #5
RachsEa
RachsEa's Avatar
Thanks Heaps for that, I no its a Clevland, I will check it out tommrow..
And My New Car..
1979 XD Fairmont
Old 25-10-2007, 08:28 AM   #6
aquahead2001
aquahead2001's Avatar
The Windsor comment is incorrect, engines known as Windors have the top radiator hose exiting the inlet manifold usually horizontally (well on carbied engines at least).
Another way to check if you have only a bare block is the timing chain housing on clevelands is cast into the block and on windsors, this is a bolt on housing.
aquahead2001 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 09:48 AM   #7
RachsEa
RachsEa's Avatar
Yeah i was only wanting to tell if it was a 351 or a 302 i no for sure its a clevo, Thanks guys
And My New Car..
1979 XD Fairmont
Old 25-10-2007, 11:40 AM   #8
LTDHO
The one and only
LTDHO's Avatar
coat hanger or drop the sump.
Only two ways.
If the motor is original you can assume the stroke has not changed and the engine code on the complance plate is correct.
As Bent 8 said
B = 4.9 (NSW only)
T = 5.8 (All states)
P = 4.9 (All 'cept NSW)
I would huess it's a 302.
Tuned by CVE Performance
Old 25-10-2007, 07:37 PM   #9
xyef351
bent8
actualy there is one other very easy way, get engine top dead center remove distibuter and look down hole if its 351 u will c either 351 or 4ma or 4mab, and if u see nothing its a 302, youll have to look down towards the back of the distributer shaft hole, looking for the front crank weight, while turning motor over by hand cant remember witch direction, been a while, you will come across the flat cut out piece on the weight and a 351 stamp if ya lucky enough, let me know how you go, and anybody else out there, i have lots of easy ways off finding out things, crammed in me head. need to free up space.
xyef351 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 07:47 PM   #10
LTDHO
The one and only
LTDHO's Avatar
The dizzy hold doesn't go down to the crank.
If it did you would see the nose of the crank.
The stamping is on the weight, further down.
Old 25-10-2007, 07:52 PM   #11
4Vman
4Vman's Avatar
His method is right, the markings are on the front journal counter weight which you can see through the dissy hole at TDC..
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 08:01 PM   #12
LTDHO
The one and only
LTDHO's Avatar
4Vman, i never knew that.
Old 25-10-2007, 08:02 PM   #13
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
i think you can only see if it is a 4MA as you can see the stamping, you can't see if it has 302 or 351 cast into it
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 08:22 PM   #14
xyef351
bent8
you will find a hole in the rear of the shaft towards the bottom get a torch, look down on an angle and u will see.
