Old 07-10-2007, 01:41 PM   #1
Burley
CRE.87V
Default au xr6 s1 hard start
hey all car has been a and it is taking like 3 attempts to start....its not happening all the time tho...wat could this be....could it be my coil pack is on the way out or starter??? i have a brand new bosch coil pack laying round at home
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 05:49 PM   #2
Scams
Scams's Avatar
Does this happen after a short drive?
scams
Scams is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 06:31 PM   #3
blackers10
blackers10's Avatar
if it is just winding over and over or stalling after starting
grab some throttle body cleaner(CRC Clean R Carb or Nulon brands i can recommend) and clean out the throttle body and EGR valve(attached to the side of the throttle body)
will help ALOT(debs was doing this and after that it idled better and was just great)
Old 07-10-2007, 07:06 PM   #4
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
Is it VCT?
Do you use premium unleaded?
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 07:27 PM   #5
blackers10
blackers10's Avatar
what could be wrong if its VCT or if he uses premium
Old 08-10-2007, 01:34 PM   #6
wazza69
wazza69's Avatar
Mine's doing this too, its a V8 though, I've cleaned the throttle body and ISC valve, but after I did that some guys said that your not supposed to on the V8's... and it seems worse now... any ideas?
Current Rides:
2015 Ford Transit Custom
1967 ZA Fairlane 289W - Thread: https://fordforums.com.au/showthread.php?t=11456233
2005 Suzuki GSX1400
wazza69 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2007, 05:39 PM   #7
blackers10
blackers10's Avatar
i ment ISC not EGR by the way LOL
all these wierd letter combos go like mush in your brain... wooooo
Old 08-10-2007, 05:45 PM   #8
sly
Sly like a G6
sly's Avatar
The TMAP might be U/S.
Sleeper, anyone?
Old 08-10-2007, 07:39 PM   #9
Burley
CRE.87V
cleaned t/b and isc last weekend....even tried a 2nd hand one i bought off au3xr...also got the map sensor too...ill try this...and yeh happens wenever really....i have been using premium for the last month or so....but was happening b4 this
