Old 05-10-2007, 11:11 PM   #1
T3rminator
T3rminator's Avatar
Default Erratic idle with A/C on
I suspect this might be more AU ECU related rather than T series specific.
I've noticed recently (last 3 weeks?) that when I drive with my A/C on the car idles erratically. When I pull up to a stop, the revs would bounce from say 500RPM to 1000RPM to 500RPM and so on. Sometimes it would just sit on 1000RPM which is quite high. Any ideas what is causing this?
I don't use the AC often but have only noticed it lately when I have had to clear the window due to fog caused by rain.
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 11:16 PM   #2
philstoj
philstoj's Avatar
Does it get better at all? i know mine does this, as i dont use the air con often, but after a bit of driving, the comp learns and it idles almost like normal.
Old 05-10-2007, 11:19 PM   #3
Stav
Smile
Stav's Avatar
The ac loads the engine and makes the idle speed drop .This is why the ecu is trying to make the car idle.It adjusts the idle speed controller up to keep the car idling. I would say clean the idle speed controller with a a cleaner.Remove the 2 allen key screws and clean it out.It may be carboned up. Failing that clean the throttle body by removing it and spraying a suitable solvent.Hope this helps
Old 05-10-2007, 11:32 PM   #4
T3rminator
T3rminator's Avatar
I usually just switch the AC on for a period of 2-3 minutes until the fog goes away...so I haven't gone for a long drive with the AC on to see if it settles down. Sometimes it idles fine...then goes cranky again at the next set of lights.
Where abouts is the idle controller?
I might do a reset tomorrow and see if that helps.
Old 06-10-2007, 02:38 AM   #5
JC
JC's Avatar
A reset should work if you have an auto and follow the relearn procedure,; not sure how it works in a manual (it's not like you can let a manual idle in gear with handbrake on).
I would suspect ISC valve too - it sits on top of the Throttle body and has a big black electrical plug attached to it.
Ford Performance Club ACT
Old 06-10-2007, 06:41 AM   #6
GK
Walking with God
GK's Avatar
This will help.
Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 06-10-2007, 09:01 AM   #7
T3rminator
T3rminator's Avatar
Hmmmmmmmmmmm think I found the culprit... I must have disconnected it when I was changing plugs. What does this thing do?
Old 06-10-2007, 11:11 AM   #8
GK
Walking with God
GK's Avatar
Question
Not sure but it's a sensor of some kind. Hooked up to intake piping so airflow or something or other!
Is it all good now you've plugged it back in?
GK
Now gone!
On LPG
Old 06-10-2007, 11:14 AM   #9
T3rminator
T3rminator's Avatar
: Its all sweet now that I have replugged it. Idles perfectly.
And that plug is the IAT sensor. Found it in the Technical Resource section.
Old 06-10-2007, 03:03 PM   #10
GK
Walking with God
GK's Avatar
Thumbs up
What does IAT stand for?
Glad it's all sorted.
GK
Now gone!
On LPG
Old 06-10-2007, 03:08 PM   #11
JC
JC's Avatar
Intake Ait Temperature. The V8s use a MAF to sense air flow, and IAT to determine air temp. I6s use a MAP - Manifold Absolute Pressure - sensor which combines air flow and temp into one reading (pressure - being a factor of Volume and Temperature).
Old 06-10-2007, 05:57 PM   #12
GK
Walking with God
GK's Avatar
Thumbs up
Another helpful service from JC's knowledge bank!
I'm glad you're still around mate!
GK
Now gone!
On LPG
Old 07-10-2007, 01:44 PM   #13
Burley
CRE.87V
hey all sorry to take the thread but mine is doing the same....bought a working isc valve thanks to au3xr....cleaned it....doesnt do it all the time...but it idles fine just sometimes the revs stay up till i switch off a/c or touch the accel
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 01:49 PM   #14
T3rminator
T3rminator's Avatar
If the idle isn't bouncing around then I wouldn't be too worried. It will idle at a different RPM compared to no AC as having AC on puts loads on the engine. Mine always idles about 100RPM higher with the AC on, and I think its normal.
Old 07-10-2007, 02:11 PM   #15
svo347
AFF's 1st DM.......
svo347's Avatar
Not entirely so, it uses variables sent from the engine temp sensor.. Both the v8 and I6 have two, one for the temp guage and one for the actual eec
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
