Old 05-10-2007, 12:33 PM   #1
haverm
Default AU 2 4.0l Idles too high
Gooday new boy here
Got a 4.0 litre AU 2 ute recently converted to gas. Everthing fine until last night when it stalled. Now idles at about 2 grand and runs like a chaff cutter.
Goes not bad at road speeds though. I'll check plugs and leads tomorrow
Any thoughts??
haverm is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 01:02 PM   #2
aye you
The Origional, The Best
aye you's Avatar
disconnect the battery for and hour, then do a computer reset, just follow the instructions in your manual, that should fix the idle problem
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 01:08 PM   #3
LPGUTE
LPGUTE's Avatar
i have the same problem. you have to clean throttle body and ISC if that dont help check vacuum if still rev about 2000RPM then the ISC is faulty
PS. welcome to the forum mate
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2007, 02:35 PM   #4
haverm
Thanks aye you and lpgute for the tips, I checked out how to diagnose the ISC on the web and lo and behold first step is to check for vacum leaks, especially the brake booster.
Well, I thought it was an unfortunate coincidence but the brakes went mushy about the same time! May have saved myself hours and dollars here. I'll update you next week after my weekend on the spanners.
Have a good one.
