03-10-2007, 01:29 PM | #1 | ||
Just slidin'
Im after diff gears, simple question, are these going to fit straight in?
http://cgi.ebay.com.au/Commodore-For...QQcmdZViewItem http://cgi.ebay.com.au/COMMODORE-FOR...QQcmdZViewItem Do I need any other parts? Whats that speedo corrector people use? Thanks.
MD Mondeo - For the family
03-10-2007, 01:43 PM | #2 | ||
AFAIK the housi ng needs to be moded for 4.11s but that can be done by the guy fitting the gears it is not a back yard job. as for speedo correctors jaycar do a kit if you have basic electronic abilities or try this http://www.shiftkits.com.au/speedo.aspx for $125
03-10-2007, 05:01 PM | #3 | ||
Just slidin'
OK, Ive decided on the 3.9's.
Can the Edit correct the speed variance? Will the 3.9's above go straight in? What else will I need.
04-10-2007, 06:54 PM | #4 | ||
Just slidin'
I just need these q's answered, so I can get the gears, puhleeasseeee anyonneee..
And thanks AU3 XR6, just the info I need
04-10-2007, 06:59 PM | #5 | ||
not sure about the gears fitting you need to talk to the guy that would be fitting it but you will still need the speedo corrector
05-10-2007, 11:20 PM | #6 | ||
Josh give these guys a call, i'll be getting by diff gears from them as we use them for our cabs. http://www.difflap.com.au/
Proud member of the All Ford Club of QLD _____________________________________________ 98 AU FORTE-Congo Green C2R body kit, 2 1/2 cat back Exhaust, Red Diamond 2800rpm stall converter BA front brakes, BA air box with pod http://www.aufalcon.com.au/cgi-bin/i...act=item&i=326 |
