Old 27-09-2007, 05:04 PM   #1
ST
ST's Avatar
Default Full power windows
Looking at getting the full power windows done for my au. What do I need? And are there any actual kits made for this?
2007 BF MKII XR6 CONQUER
ST is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 06:39 PM   #2
Jokular
Jokular's Avatar
I know there are items on ebay that you can buy for this.
a search for "au window" pulls some good results.
there is also some window buttons to operate rear windows that go on the drivers side door.
Seems like a reasonably cheap conversion, for parts at least.
I reckon there would be a few people on here that have done this alas i am not one of them.
My Car
Jokular is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 08:28 PM   #3
waggaclint
waggaclint's Avatar
yeah im interested in this too....my AUIII already has power fronts but id like to convert the rears...does anyone one no whats involved...is there wiring etc already there????
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 08:43 PM   #4
b2tf
not here much anymore
b2tf's Avatar
The loom wont be there unless its a mid/high series vehicle, in which case you'd have power windows already there.
You'll need to run power to the windows, change the mechanisms (the windup ones are different), and I think you may even need to change the BEM to make it all work, not 100% sure on that though.
Its reasonably simple if you can get a hold of all the parts.
2024 F150 XLT
Old 27-09-2007, 10:06 PM   #5
private9
www.TUFFCARPARTS.com
private9's Avatar
If you're patient, I'll have the window regs and switches available from my Fairlane when I get around to pulling it apart.
Old 27-09-2007, 10:10 PM   #6
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Get in touch with LG - he has done this conversion. It is not a cheap one.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 10:10 PM   #7
b2tf
b2tf's Avatar
let me know when you start, ive got a nice little shopping list :
2024 F150 XLT
Old 28-09-2007, 10:50 AM   #8
ST
ST's Avatar
I have a series I with power windows in the front, so am I looking at an expensive conversion for the rears?
Old 28-09-2007, 01:20 PM   #9
private9
private9's Avatar
I'm only guessing here for the AU, but I know with EF/EL's in a Futura for example where there is power front windows, but manual rears, the wiring looms will already be present for the rears. In the EF/EL's all you have to do is put in the reg, plug it in, and then plug your new window switches in front and rear - all pretty simple.
Hopefully it's that easy for the AU!
Old 28-09-2007, 01:23 PM   #10
private9
private9's Avatar
No worries Aust, will no doubt start a thread when I do - I haven't even seen the damn thing since the day I bough it about 3 months ago!
Out of curiosity though, PM me with what you'd be after!
I'll probably start it very late this year, or early next year. Once I've pilfered what I want, I'll put the rest up for wrecking.
Old 28-09-2007, 03:38 PM   #11
chief
FTF Club Moderator
chief's Avatar
I have done the conversion. It was a little expensive but I think worth it. A word of advice clean the contacts in the switches before you install them.
What you will need:
Power window regulators,
wiring,
the looms,
the switches,
door trims. - its not essential but you will have an empty hole in the door trim otherwise.
I picked it all up at FTG for a couple of hundred dollars and a phone call to Stav (from Stingray Car Security) to install them. Took a few hours to install.
With the conversion, you dont need the drivers door 4 way switch. If anything it will make it easier to install.
Albert Einstein:
Fords in the Park 2010
Old 28-09-2007, 04:33 PM   #12
superroo
You can't stop the signal
superroo's Avatar
Just did my fronts in the ute two weeks ago. Cost $400 all up and about 2 days to do it.
From a wrecker i brought:
Front door trims
Front Regulators
Both front switched
That cost $350
Then the other $50 was buying automotive cable from autobarn/supercheap which i used to create my own looms and narva automotive connectors to hook it all up.
Which on that note, the narva connectors are fantastic things. The 2 prong connectors were a straight hook up to the plugs on the regs and the 6 prong connectors fitted straight onto the switches.
Easy enough to do if your confident with electronics and stuff. I've even got mine running off a relay and fuse in the factory fuse box position for them. I've just haven't been able to connect into the BEM to get the 30 second delay function, so they're on all the time.
Best advice i can give if your going to do it all your self, is get a hold of a gregories/elery manual for the car, and use the wiring diagrams on here to your advantage. They make things alot easier.
If you only have to convert the rears, then you will need:
2 rear door trims
2 rear regs
2 rear switches
1 new main switch
+ wiring which you can create your self
Have a look on the wiring diagrams on here and then decide if you feel confident enough to tap into wires to hook them in
