Old 16-09-2007, 10:47 AM   #1
InfernoSR
Sales Representative
InfernoSR's Avatar
Default Battery going flat...
We found that my battery goes flat in about 2 days. I purchased this car with this problem, as the seller had told me that whenever he went anywhere, or when the vehicle will sit for a while, he would disconnect the battery : ... but never told us he did it due to flat batteries :togo: ... he had installed a terminal disconnector, he installed it on the earth (good boy) and all you have to do is wind it in to connect it.
Now... we believe it maybe a problem with leakage from the alternator... any other suggestions?
Old 16-09-2007, 11:47 AM   #2
accurate1
Connect a Digital multi meter at the battery to measure parasitic current draw, if it is more than about 50 milliamps start pulling fuses one at a time until it drops down to almost nothing. This will at least tell you which circuit has the problem, it may be as simple as the boot light on all the time.
accurate1 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 12:13 PM   #3
JC
JC's Avatar
Genius solution! It's why I like these forums - there's always a solution "out of the box" that means you can locate the issue yourself, instead of paying a sparky $80 an hour to do the same thing - may still the sparky to rectify the issue, but at least it's already been identified.
Ford Performance Club ACT
Old 16-09-2007, 12:20 PM   #4
InfernoSR
InfernoSR's Avatar
Is that just using the DCV measure?
And you dont need to pay the sparky for the diagnostics :
Old 16-09-2007, 12:24 PM   #5
Stav
Smile
Stav's Avatar
Blueprint ..you helped me with your posts and Ill help back. Go to the car and do this check.Pull down your rear seats and look into your back boot.Is the back boot light on all of the time? If so then your back boot light switch is faulty.Also do you have a car alarm?
Old 16-09-2007, 12:30 PM   #6
InfernoSR
InfernoSR's Avatar
No to car alarm, and the boot light is off...
And as i said before... i'm here to learn and to help others with what I know.
Old 16-09-2007, 01:48 PM   #7
Clamp on DC ammeter is best way to check source of current leaks as you don't need to disconnect anything and you can follow the wiring harness along and branch off as required to track the source.
Old 16-09-2007, 03:28 PM   #8
sly
Sly like a G6
sly's Avatar
In the same vein, if your glovebox lid droops a bit the gb light can be on all the time. When it gets dark, check if any light is coming around the lid.
Sleeper, anyone?
Old 16-09-2007, 03:34 PM   #9
InfernoSR
InfernoSR's Avatar
ooo, never thought of that... thanks.
