05-08-2007, 11:10 PM | #1 | ||
Big Al
I came a cross some old stuff i downloaded from fordmods some time ago, and tried it out today, bit of a trick but eventually got into it, which is through a second by second input on the odometer button you can get into a screen 'setup' 19 dual screens in total some are usable and some to me are not, its a split screen, upper and lower, one is real time rpm another is whats left in tank fuel wise by the L, another is real time temp and real time fuel usage, another what gear you are in 1 to 7 1 = first and 7 = park, real time voltage output, and many others i can't or don't get a reading from, the last one is 'Ford' flashing, does anyone have a listing of all screens functions and is there some way of getting logged codes from one of these screens, if u have a ex police au u can also change the speedo reading by 5% intervals eather faster or slower.These "screens" are apparently available to all au's series 1,2and 3 + ex police cars (speedo)
05-08-2007, 11:13 PM | #2 | ||
How do you do this? would be interested in sussing it out.
05-08-2007, 11:17 PM | #3 | |||||
Captain Malcolm Reynolds
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
05-08-2007, 11:22 PM | #4 | ||
Big Al
Ford AU Series 1 to AU Series 3 Falcon, XR, Fairmont, Fairlane, LTD and Ute Instrument Cluster Diagnostic Mode
A big thankyou goes to AU2SR - Aka Jeff for Finding this bit of hideen information, and for allowing Fordmods to host this document ! This document describes the Falcon AU Dash Diagnostic Information that is provided when the Dash is placed in Diagnostic mode The information that is returned is displayed using the Odometer display area, and includes the information that is transferred on the ECU bus This includes Fuel level, Fuel consumption, oil pressure, Coolant Temperature, RPM, Vehicle speed, Gear lever position, Door Ajar, and many others Entering Diagnostic mode The diagnostic mode can be entered by using the following method • 1) With the ignition key in the off position, turn the Ignition Key to the On Position. • 2) Using the Odometer Button, Press the Odometer Button Down, then release 5 Times within 10 Seconds (Note : You must be very accurate with the timing. Depress the Button for 1 second, then release for 1 second. Do this 5 Times in 10 seconds) • 3) Release the Odometer Button for 5 seconds. • 4) Depress the Odometer Button for 7 Seconds. • 5) Release the Odometer Button for 5 Seconds. • 6) Depress the Odometer Button for 7 Seconds. You should now be within the AU Instrument Cluster Diagnostic Mode Within Diagnostic mode, there are 19 Diagnostic Screens that are available. At the moment we do not have enough information as to what all the screens actually are. To Exit the Diagnostic mode, Depress the Odometer Button for 11 seconds. More Information will be made available as to what diagnostic sections display what type of information soon ! Diagnostic Codes Mode Top Line Bottom Line 1 Petrol in Litres (No Level Buffering) Petrol Sender Resistance (Unbuffered) 2 Coolant Temperature (Degrees C) 3 Engine RPM Vehicle Speed (KM/H) 4 Oil Pressure (Bar, 1 decimal Point) Battery Voltage (Volts) 5 Instant Fuel Consumption (L/100Km) Instant Fuel Consumption (x 0.1 Litres) 6 Fuel used since Trip Avg L/100 Reset (x 0.1L) This Value is used to calculate the Trip computer Average Fuel consumption L/100Km Kms Travelled since Trip Avg L/100 Reset 7 Buffered Fuel Tank Level (In Litres) Value used for Petrol Gauge Buffered Fuel Tank Lever Sender Resistance 8 Gear Position (PNRD321) 9 Unknown - 0000 Unknown - 1111 Changes on AC Clutch Engage 10 Unknown - 0000 Unknown - 1111 11 Unknown - 0000 Unknown - 1111 12 Unknown - 0 13 Unknown - 0 14 Unknown - 0000 118 15 Unknown - 0000 255 16 98 112 17 Unknown - 0 0 18 -o-d ---- Police - (Ex Chaser) Instrument Clusters In addition to the above diagnostic modes, the Police (Chaser) Instrument clusters also have a Speedo Calibration mode. The Police (Ex-Chaser) instrument cluster allows re-programming of the Speedo Reading, (and consequently the Odometer), so as a Precise Speedo Reading can be made. This also means that the Speedo can be re-calibrated, when making changes to the Factory fitted wheels, Tyre Profiles, as well as altering differential Ratios. To determine if you have a Police (Ex Chaser) Instrument Cluster fitted, try the following Routine, to enter the calibration mode. To Calculate Calibration figures for the Police Instrument cluster, when making the above modifications, please check the Diff and Tyre Calculator Page. Warning : Playing with the Instrument Calibration feature will modify your Speedo, and Odometer readings. Please be sure of the consequences of changing these settings, and also Make note of your Original Calibration Setting This will ensure that you can return the Speedo Calibration Back to its original condition, if modified. Entering the Police Instruments Calibration Mode - (Police AU Series I models) • 1) With the ignition key in the On position, press and hold the Odometer reset knob for 5 seconds, then release. • 2) The Odometer will then display "SPEEDO #.#" - where #.# is the Speedo calibration Percentage, and is set to "0.0" Percent from the factory. • 3) To increase the Percentage adjustment, Press the Odometer reset shaft for a short period of time (0.2 to 0.7 seconds). This will increase the adjustment by 0.5% • 4) To decrease the Percentage adjustment, Press the Odometer reset shaft for a long period of time (0.8 to 4.9 seconds). This will decrease the adjustment by 0.5% • 5) To exit the Speedo calibration mode, press and hold the Odometer Reset shaft for a period longer than 5 seconds. Entering the Police Instruments Calibration Mode - (Police AU Series II - AUIII Models) • 1) With the ignition key in the Off position, press and hold the Odometer reset knob • 2) Turn the Ignition Switch On, and continue to hold the Reset shaft in for 5 seconds, until the cluster enters calibration mode, (Typically 5 seconds) • 2) The Odometer will then display "SPEEDO #.#" - where #.# is the Speedo calibration Percentage, and is set to "0.0" Percent from the factory. • 3) To increase the Percentage adjustment, Press the Odometer reset shaft for a short period of time (0.2 to 0.7 seconds). This will increase the adjustment by 0.5% • 4) To decrease the Percentage adjustment, Press the Odometer reset shaft for a long period of time (0.8 to 4.9 seconds). This will decrease the adjustment by 0.5% • 5) To exit the Speedo calibration mode, press and hold the Odometer Reset shaft for a period longer than 5 seconds. |
06-08-2007, 08:45 AM | #5 | ||
I had a thread on this a long time ago as well ... it can be quite useful ... I was testing an issue I had with overheating at one point and running the diagnostic in the Temperature mode most of the time.
Also since my LPG senders were playing up I was watching the unbuffered resistantance levels to see when I was having the issues on the senders going out of range as well. Also I found out ... for Option 2 ... the other field next to coolant temp is actually the DTE reading for the cluster as well. Another thing I found too is ption 14 reading changes from 0000 to 28 ... sometimes ... I still can;t figuer out why though. Also the digital speed readout is different from your analogue speedo as well ... by about 1-2 km/h. Have been using it regularly ... it is quite a handy tool ... especially on the dyno (trying to figure out temps ... and to see if my cluster temp gauge was actually working and not telling porkies).
06-08-2007, 03:04 PM | #6 | ||
not here much anymore
Interesting, is it like the EF/L one though where it reverts back after 10 mins or so?
2024 F150 XLT
06-08-2007, 03:21 PM | #7 | |||
09-08-2007, 07:56 PM | #8 | |||
12-05-2010, 10:41 AM | #9 | ||
Wow this is an old thread. I tried doing it but it doesn't work.
Au xr6: tickford kits, tickford 17s, momo T Bar and wheel, leather, lowered on ultra lows, 2.5" cat back with hot dog muffler, K&N panel filter and loving the car as a P plater Future mods: 19" staggered wheels Clear side indicaters. That is all |
12-05-2010, 10:52 AM | #10 | ||
try with a stop watch, it has to be exact
12-05-2010, 10:55 AM | #11 | ||
I tried it about 6 times with a stop watch and was exact everytime I pressed the odo button in.
13-05-2010, 10:53 AM | #12 | ||
With da Warlords
It works, but you have to be bloody accurate with the timing. I've had to to do it up to 7 or 8 timnes to get it right. I also figured out that if you have the police cluster like me, you cannot use the dash diagnostic mode.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
13-05-2010, 12:12 PM | #13 | ||
How do I know if I have the police cluster?
13-05-2010, 12:46 PM | #14 | ||
Flairs - Truckers Delight
2 kilometer increments on the face rather than 5
13-05-2010, 12:48 PM | #15 | ||
With da Warlords
And no tickford wings or blue fascia in my case. Just plain black and as said, 2km increments.
13-05-2010, 12:53 PM | #16 | ||
Ohhh ok well then i dont have a police cluster. Ill go out now and try the diagnostics mode again. If it doesnt work after the 8th time then I give up lol.
how do i know if im in it and how do i toggle from each mode?
13-05-2010, 01:17 PM | #17 | ||
If you're in it you'll lose the odo and normal bits and pieces and will show two lines with random numbers. Just push the stalk to change modes.
15-05-2010, 10:08 PM | #18 | |||
Former BTIKD
15-05-2010, 10:38 PM | #19 | ||
haha I actually found it on google. I clicked it and found this interesting so tried it but it never worked
