Old 30-07-2007, 07:57 PM   #1
Auuteage
Default is there any way of checkimg/topping up diff oil?
Having a slow axel seal leak, I have a feeling my diff sounding like a plane around 70 and beyond may be due to the fact that it may well have no oil in it.
So, is there a way I can check it/top it up? thanks
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 07:59 PM   #2
FGII-XR6
FGII-XR6's Avatar
there is a plug on the cover plate the oil needs to filled till it is up to this level. check how far down it is by sticking your finger in. if you can't feel oil it is way too low
Old 30-07-2007, 08:15 PM   #3
Auuteage
Can oil be added from this hole?
Old 30-07-2007, 08:23 PM   #4
mik
mik's Avatar
yes sure can
Old 30-07-2007, 08:43 PM   #5
rag top
rag top's Avatar
might also be worth draining what is still left, and fill up with some fresh oil.
Bottom bolt of the rear cover is the drain plug.
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 08:51 PM   #6
FGII-XR6
FGII-XR6's Avatar
and pray there aren't little gold flecks in the oil
Old 30-07-2007, 08:54 PM   #7
Auuteage
What exactly would gold flecks mean?
AND, can I go up to the servo and get diff oil?
Old 30-07-2007, 09:00 PM   #8
nikos
mezzo forte
Gold flecks mean you've ground up your gears due to lack of oil, not good!
You can go to a servo but its probably cheaper from supercheap or autObarn
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 09:08 PM   #9
Auuteage
Well its worrying me enough that IM thinking of doing it now. I do 300kms a day, its gotta be not doing any good!
Old 30-07-2007, 09:18 PM   #10
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
I changed mine over the weekend.
A few observations, old diff oil is STINKY!
Its probably easier to do than a normal oil change, well on a ute anyway.
Make sure you use the right oil, its different if its an LSD or not.
Have fun!
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 09:24 PM   #11
Auuteage
Have fun!
yeah fair point. Its not LSD I think. There is only the ONE nut though on the diff centre. So drain and fill through this one hole yes ??
Old 30-07-2007, 09:25 PM   #12
bodes-sh
no....the drain hole is the small one in the middle at the bottom....
Old 30-07-2007, 09:26 PM   #13
Auuteage
Ill have another look. All I could see was one largish nut around the middle roughly
Old 30-07-2007, 09:36 PM   #14
GK
Walking with God
GK's Avatar
This may be of help.
Changing Diff Oil
http://www.fordforums.com.au/showpos...7&postcount=42
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 30-07-2007, 09:37 PM   #15
Auuteage
For a quick fix before the serivce is due on the weekend I might just top it up. Any tricks for getting oil in through that hole though? Dosent look easy :0)
Old 30-07-2007, 09:40 PM   #16
Auuteage
That does help GK, thanks. I presume the oil pictured is for a AUII.
Old 30-07-2007, 09:48 PM   #17
GK
Walking with God
GK's Avatar
No worries.
Yep, that oil went into my S2 live axle. I've since used the same oil in the S1, no difference. But if your car is LSD, you will need an additive, and perhaps even different oil.
GK
Now gone!
On LPG
Old 30-07-2007, 09:49 PM   #18
Auuteage
Its a stock AUII one tonner. As far as I know, its not LSD. 99% sure.
I have a awful feeling the diff may well be bone dry. About to find out
Old 30-07-2007, 10:25 PM   #19
loxxr6
XB in parts...
loxxr6's Avatar
Changing Diff Oil
Cheers,
GK
Nice write up. I've been meaning to check my diff oil for ages. Might be time for some maintenance on the car.
Old 30-07-2007, 10:34 PM   #20
ClassicAU
Ever so handy with the write up GK, as usual! Good work. How often should the diff oil be changed? I think its almost been a year since i had my LSD built, is that too long?
Evan
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 11:52 PM   #21
GK
Walking with God
GK's Avatar
I guess you could go every year or so. That's probably overkill for average use though.
Many of us like to be that way of course.
GK
Now gone!
On LPG
Old 31-07-2007, 06:13 AM   #22
au2sw
Blown 5L coming
au2sw's Avatar
basically with diff and transmission, if it starts looking really dark and has a very pungent odour, change it. watch for metal flakes, this measn the gears are getting chewed up. a small amount is normal wear and tear, but large flakes is bad. autos are recommended to be serviced every 20,000ks. a full auto flush probably evey 100,000. though im not entierly sure as ive never had to do one.
auuteage, replace the axel seal as soon as you can, youll just have to keep topping up constently, not to mention the mess it makes over your brakes and tyre and wheel arch/guards if you dont replace it.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 09:45 AM   #23
Robe
It is funny in this day of chips and sophisticated engine systems that we still have to stick our finger in to check the diff.
And then bang our heads on the underneath bits of the car while trying to convince diff oil to get in.
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 01:25 PM   #24
JC
JC's Avatar
Easiest 2 ways of getting diff oil in:
1. Use one of those hand pump syphons you can get for about $2. Throw away after use.
2. Get a small weed spray kit - the kind that you pump up with air, and then release a trigger on the flexible hose nozzle to allow flow. Clean well after use.
Ford Performance Club ACT
Old 31-07-2007, 05:36 PM   #25
Auuteage
Turns out it isnt the diff or lack of oil at all, but a wheel bearing! Cant get it fixed till the weekend, so I have 3 days of very stressful driving hoping the bearing dosent heat up my axel enough to snap and I lose a wheel on the highway! Its going to be a slow three days.
If any of you feel enlightened to give me some silly odds of this actually happening to make me feel better, feel most free!!!
Old 31-07-2007, 06:41 PM   #26
Auuteage
A mechanic just told me that its unlikely a bearing will actually seize as long as your diff has oil in it. Possible, but unlikely. Whatchya reckon?
