Old 19-07-2007, 07:55 PM   #1
50%ofpopulation
Default Cleaning Leather steering wheel
Hi everyone,
I own an NL Fairlane Ghia with a factory fitted leather steering wheel in grey.
I have noticed a build up of white specs on the surface of the wheel - how do I get them off?
I have worked out its not paint - but from a white peppermint wrapper.
I have tried leather cleaner in paste and foam cleaner, but no results.
Live by the Ford, Die by the Ford.
50%ofpopulation is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 08:32 PM   #2
shane3
FPV GT 0915
shane3's Avatar
Can't see the spots, bad pics!, If they are a build up on your steering wheel I would use a knife and VERY carefully scrape them off, hold the blade at 90o (square) to the wheel, so you don't cut into the leather, try to scrape them off then try to cut them off.
Bluprint BA GT 2004 Model - Mods: Tinted Windows, Premium Sound, BBS Mags, 245/35R19 fronts, 285/30R19 rears, BMC POD Filter, SS cold air induction, HM tri-y headers, Redback cat back system, Herrod power snorkle, moded Herrod helix spacer, 4" ram air induction, More to come..
shane3 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 10:08 PM   #3
myxr6
I use a product called "Dubbin" on my steering wheel.It's used for leather shoes and sports equipment and as a conditioner.
myxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 10:23 PM   #4
gz1
gz1's Avatar
In cases like that I have used the old duct tape. The heavy duty cloth one, just fold a piece around your hand with the sticky side out and dab at the wheel. All that stuff will stick to the tape and come off clean. Once you have done that clean the wheel with a good quality leather cleaner and should come up like new.
gz1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2007, 03:45 PM   #5
50%ofpopulation
Can I use electrical tape?
Old 20-07-2007, 04:00 PM   #6
gz1
gz1's Avatar
I've never tried that but you can try it, It won't hurt. Basically all you want is something sticky that all those small pieces can get stuck on and be pulled out.
Old 20-07-2007, 04:29 PM   #7
50%ofpopulation
Thanks for that. I gave it a go and the wheel came up trumps - I placed strips of the tape over sections of the wheel rim, and rubbed over it to remove air bubbles, gave it a few seconds and that worked best.
It was like giving my wheel a "Brazilian Wax" LOL
Then I rubbed some Megaruis leather cleaner over it.
