Old 12-07-2007, 09:41 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default steering dramas
Re the other thread I started on the weekend - PS fluid was really low so I topped it up and made sure it was right.It hasnt been leaking, been keeping an eye on it, but I find now that if Im turning left (yes only left) around 40-50kms, Im getting a grinding sort of sound coming from the car. I've checked the tyre pressures, switched over the rims, checked the wheel nuts and made sure there's nothing hitting the wheels etc, but its still there. Any ideas on what it could be? Almost sounds like something's loose?
2024 F150 XLT
Old 12-07-2007, 09:44 PM   #2
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
My s3 XR8 sedan does this as well so if any one has ideas that would be awsome. I have looked and looked and cant seem to find anything rubbing.
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 10:46 PM   #3
bodes-sh
could you be a bit more specific on where the noise is coming from, ie front, rear, left, right, etc...that may help a bit, as it could be anything
Old 12-07-2007, 10:55 PM   #4
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
mine is on both sides at the front of the car. Which ever way you turn thats the side the noise comes from
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 12-07-2007, 11:50 PM   #5
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
this is what I was talking about with the noise Austin- probably air in the system?
Or you p/s pump is now cactus.
I would bet that the noise will go away, but I would be replacing the P/S fluid with the right stuff, remembering the recommended stuff is a light hydraulic oil or specifically Castrol Syntrans manual transmission oil.
Keep an eye on it mate, but it could just be air....... Just seems conicidental that it's after you topped the reservoir up
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2007, 01:18 AM   #6
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
Thats a good point i might check mine this afternoon. Actually on a 200,000km service does ford do P/S checks?
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 13-07-2007, 01:50 AM   #7
FGII-XR6
FGII-XR6's Avatar
sounds like air lock turn wheel full lock and hold it there a few seconds 3 or 4 will do(you'll hear the releif valve scream but thats ok) repeat in the oposite direction do this left right cycle 6 or 8 times if problem is still there then do it again but 12 to 14 times that will get rid of the air lock
Old 13-07-2007, 02:19 AM   #8
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
sweet as hope it works the noise sounds horrible
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 13-07-2007, 07:20 AM   #9
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
The other possiblitly it could be is your diff fluid. If your car has an LSD, you might need to add some LSD fluid to the diff.
I had this exact same problem. Got a grinding (and/or clicking/clunking) noise a low speeds when steering...
Easier to fix too then a power steering issue...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
