21-05-2007, 10:38 PM | #1 | ||
Hey all, new to the forum and I need some info. I have a series 3 AU XR6HP, blueprint in colour and completely standard. I'm looking at moding it, and I'm aiming to have 220KWRW. What would be a good starting point and how would I do it without turbo or charger.
Cheers. |
21-05-2007, 10:42 PM | #2 | ||
BrwnBstd
Nitrous Oxide !! :-)
21-05-2007, 11:02 PM | #3 | ||
A Spoon engine, t66 turbo with nos and a MoTeC system exhaust.
21-05-2007, 11:08 PM | #4 | ||
Young !@#$ Head
your best bet would be a turbo kit. But start with an exaust 2 1/2 inch a nice cam and a new computer. But if you do go turbo you will need another computer again so keep this in mind if you buy one first.
21-05-2007, 11:38 PM | #5 | ||
SS Grunt
With a N/A 6cyl making 220rwkw's with no boost or juice(nos) the car would not be street drivable, it would idle and drive at low rpm's like a pig.
The Beast has gone to a new home Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW I will also enter any part of the Forum I wish to enter. : |
21-05-2007, 11:56 PM | #6 | ||
umm my mate, use to own a el fairlane, 6 cylinder. He had:
port n polish on the heads only mild, billit cam custom grind, HP4 chiptorqe chip, pacemaker tuned length extractors, exhaust, 3.9lsd, shiftkitted box. ran a 14.6 @ 97mph 206RWHP or 158RWKW. another guy. http://www.fordforums.com.au/showthr...ghlight=oed666 |
22-05-2007, 12:01 AM | #7 | ||
not here much anymore
You're going to be fighting an uphill battle to get a 6 to that kind of power level unassisted by a turbo, blower etc. If you want to stick to N/A, the usual mods are probably the best way to go:
Exhaust and extractors Cam + headwork Intake Tune - always do last That could get you around the 170rwkw mark depending on what products you use. Turbo you will get 220rwkw very easily provided you don't skimp on the parts or the tuning.
2024 F150 XLT
22-05-2007, 12:10 AM | #8 | |||
N2O and some serious piston /compression/cam / computer/injectors and 'zorst |
22-05-2007, 01:06 AM | #9 | ||
if u are going to turbo your car, u are better off doing it all right the first time, when i was thinking about doing it, i was just gonna purchase a second hand motor off ebay ($300), i was gonna still drive my falcon around and just do the other engine up slowy. Pull the engine apart, recondition it do all the pistons and what not all in one go. i still would be able to drive my car, but would be building one tuff engine over time. Have all the other stuff ready, and over a one week holiday, take the old engine out and in with a brand new one, change the dif and all that over then too. week after that have it tuned and hopefully all sweet.
22-05-2007, 09:15 AM | #10 | |||
SS Grunt
22-05-2007, 09:28 AM | #11 | ||
If your looking at 220rwkw's n/a, its doable if you have 50k+ to play with. It would be alot cheaper, and easier just to go fourced
22-05-2007, 10:24 AM | #12 | ||
Back to the AU
Sounds like a decent supercharger would be a good option here. Seriously, unless you are planning on spending a lot of time researching and a lot of time with your car off the road then it might be good to readjust your target.
If you're completely set on NA, then 160-170 rwkW would be a reasonably attainable target. If >200rwkW is a must, then forced induction is the most practical (by far) solution. Just budget for a solidly upgraded drivetrain as well. Give us some more insight into what you really want to achieve so that we can point you in a direction that you're most happy with.
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU 2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth |
22-05-2007, 10:37 AM | #13 | |||
22-05-2007, 01:11 PM | #14 | |||
2.5” Exhaust Extractors Hi-Flow Air filter or Pod Bigger air intake 90mm piping from air box to throttle body 78mm throttle body ? (any help here) Flash/custom tune (later) and any other small improvments. Cheers. |
22-05-2007, 01:18 PM | #15 | ||
That list should get you around 100rwkws short of your goal
22-05-2007, 02:26 PM | #16 | |||
2024 F150 XLT
22-05-2007, 02:52 PM | #17 | ||
SS Grunt
220rwkw in a N/A 6cyl would require almost 100% Volumetric Efficiency (VE), so to achieve this you would need a better intake manifold which would be a custom made type, and now lets get into the cam side, no cam on the market would get you this power you are after, it would be a custom grind and would have so much duration and lift that with the std valve sizes it would be pointless not to mention need a 4000+ hi-stall or a manual. Cylinder head would need to come off with larger valves and porting done, then to run this big cam to its max it would need more compression so you will need to sort that out aswell, when the cylinder head is off getting the bigger valves and porting you will need to get the pistons notched out for running the bigger cam and larger valves. So add all this up plus the tuning needed and posibly new bigger injectors and if its in your price range then have fun.
22-05-2007, 02:55 PM | #18 | ||
SS Grunt
It would seriously be less mucking around if you just get the $4000 Powerdyne blower from CAPA. It comes in a kit.
22-05-2007, 03:14 PM | #19 | ||
With da Warlords
I agree, way too hard to pull that power from a 6 N/A. I've done all the usual bolt-on parts to my 8, and I'm still 20rwkw short of what your after
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
22-05-2007, 03:54 PM | #20 | ||
If you mean 220rwHP, than that's around 160rwkw, and is achievable with headers, exhaust, cam and tune. No point going bigger TB or intake piping, as the head just won't flow enough to require the extra air, and you will lose air velocity, which adversely affects torque (down low).
22-05-2007, 03:59 PM | #21 | |||
22-05-2007, 04:33 PM | #22 | |||
Back on the road
The AU I6 head flows some pretty good air. If you couldn't make 160rwkw with the std head, then you need to find another tuner and/or cam grinder... But then, peak rwkw is not everything, so why worry about it?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
22-05-2007, 04:55 PM | #23 | ||
I can't see where his list of planned mods mentioned a cam. Yet again I stand by my statement. But your spot on XRUTE peak kws is not everything or what should be your main concern
22-05-2007, 08:26 PM | #24 | ||
Long story short, buy a V8.
23-05-2007, 08:52 AM | #25 | |||
Evan |
23-05-2007, 09:38 AM | #26 | ||||
23-05-2007, 09:52 AM | #27 | |||
23-05-2007, 12:04 PM | #28 | ||
I think it can be done... just need to spend the $$$ on it, alot of $$$.
The I6 even though missing the extra 2 cylinders arent far behind the 5L's when both are stock. It dosent take much to whip a baby 5L anyway even if they have a few bolt ons. I know ive embaressed a few. The extra 2 cylinders only slow them down :P lol To get the 220rwkw out of a 6, it will require a full rebuild.. and be built high comp. Which will make it a revvy peaky car... and some people like that.. a 6cylinder at 8000rpm would be unreal. In reality you wouldnt get much change from about $5500-6000 for the bottom end, about $4000-4500 for the head and cam, then ontop you need extractors/exhaust, intake(probably a custom inlet manifold or extreme inlet manifold work), fuel system (pump and injectors), and a good engine management system (Edit), another $3000. With all your new found power you will need a gearbox to handle that, rebuilt auto or a stronger manual/clutch kit, factor in another $3500 or so. And it will still scare off most 5L worked or not. It can be done, its just that no one wants to spend the money, they take the easy way out and go force fed. |
23-05-2007, 02:41 PM | #29 | |||
SS Grunt
You also mentioned that the extra 2 cylinders just slow it down, completely wrong, it all has to do with the rod ratio's and things not how many cylinders there are, and how much weight its packing in the bottom end and windsors are far lighter in the rotating assembly then the I6, I6's rev slow compared to a 5L windsor.
23-05-2007, 04:21 PM | #30 | ||
You missed the sarcasm with the 2 cylinders slowing them down.. I know its wrong, just **** stirring. I love my 8's, dads got an F100 with a 302w in it and I love it. Ive got a 429cu ford big block sitting in my garage.
But the baby windsors need alot spent on them to get them going hard just like the 6's do. What gets me though is its always "get an 8" or "turbo/supercharge".. you dont have to do that to get a quick car. There is a bigger aftermarket base for the 8's at this stage, give it time and it wont be long till the 6's are right up there. The 6's are becoming more appealing the more our tuners fiddle with them and start unlocking the potential these engines really have. |
