Old 27-05-2018, 01:44 AM   #31
Crazy Dazz
Default Re: Burning your Oil (instead of changing)
Gotta love how the experts like to proclaim "it's the LAW", as though Moses is gonna come down from the Mountain and Smite Thee.
I'm not sure what rules different states have, but certainly nobody in WA gives a rats ****.
We're talking about the controlled consumption of maybe 1 part per thousand.
So provided your car still complies with the relevant ADRs, and isn't demonstrably dirty, there would be no problem.
We're actually far stricter on Underground mines, all vehicles have to be routinely tested. But these were open pit haul trucks.
As a general rule, we insist on compliance to Australian Standards, but I'm not even sure what standard exist for these engines. Even on the mid-sized trucks, the engines are around 70L. The big ones are over 100.
Old 27-05-2018, 07:45 AM   #32
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
I have heard of one such trucking company that got caught dumping their waste oil into their diesel tank. And burning it off that way. Highly illegal.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2018, 09:18 PM   #33
aussie muscle
aussie muscle's Avatar
Originally Posted by ebv8 View Post
mitsubishi have been doing this for years, been behind an early magna or pajero?
old valiants i had were that sort of oil burner. so long as you kept them topped up, they'd keep going and going...
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2018, 09:42 PM   #34
Crazy Dazz
I'd be really interested to know what law they were found guilty of breaking? Only thing I can think of is perhaps a law related to the disposal of hazardous waste.
Old 31-05-2018, 10:20 AM   #35
They burn oil in Formula 1 as a power additive.
But they are not allowed to
https://www.insidesport.com.au/news/...burning-466160
The FIA has signalled it will redouble its efforts to stop Formula 1 teams potentially attempting to gain an engine power increase by deliberately burning oil in the combustion procedure.
The oil-burn controversy came to light earlier in the year when Red Bull Racing said it suspected its rivals had found a way around the regulations surrounding the internal combustion component of the hybrid power unit.
In response, the FIA took a closer look at oil usage and consumption, and the chemical composition of the oils being used.
The FIA has now confirmed that the use of chemicals in oil that could help improve combustion is not permitted.
Head of the F1 technical department, Marcin Budkowski, wrote to the teams to re-emphasise the FIA’s position that the use of oil as fuel is prohibited.
"For the avoidance of doubt,” Budkowski wrote, “the only fuel that may be used for combustion is petrol, and the only permitted characteristics of that petrol are clearly set out in Article 19 of the technical regulations.
"Even though the technical regulations do not directly specify the permitted characteristics of engine oil used in F1, we would consider any attempt to use additional components or substances in oil for the purpose of enhancing combustion as a breach of the technical regulations."
Regulation changes planned for next year will require teams to supply the FIA with a measurement of the level of its mail oil tank at all times, will ban active control valves between the power unit and engine air intake, and limit teams to a single specification of oil per engine at a grand prix.
How it works here https://www.matfoundrygroup.com/News...urn_Engine_Oil
One method understood is the addition of second set of injectors at the bottom of the cylinders - below the pistons and just above the crank shaft – which sprays a mist of oil onto the underside of the pistons.
When timed correctly on the down stroke, the increasing pressure in the crankcase will force the oil vapour through the oil ring grooves. Usually these grooves are positioned under the oil ring so they can fulfil their job of collecting the excess oil gathered by the oil ring and channel it back down into the crankcase. However if you modify the number and shape of these channels, and reposition them higher up in the ring seat, you can turn the oil ring into a valve of sorts and control the flow rate of oil allowing it to enter the chamber.
All of this works together to achieve a noticeable increase in performance by circumventing fuel limits and additive restrictions - hence the debate on whether it was within the rules or not.
For you average car this isn’t necessary at all. You don’t have a fuel limit or a restriction on what additives can be added to your tank and so circumventing these isn’t needed, and neither is burning oil. If your engine starts smoking excessively from oil making its way into the combustion chamber and being it burnt, it's still very likely you have a problem that needs fixing.
and https://www.motorsportmagazine.com/o...ing-rule-tweak
Using oil in the combustion process in these fuel flow-limited and highly knock-sensitive engines liberates extra horsepower. Oil is less combustible than petrol, but if used for combustion off-throttle, it allows a leaner, more combustible, petrol/air mixture to be used on-throttle when it matters. It effectively allows you more bang for your fuel flow-limited limit buck.
Old 31-05-2018, 10:27 AM   #36
Rotary engines also burnt oil to keep their apex seals lubricated.
e.g. http://www.rx8help.com/before_you_buy/burning_oil.html
and https://nationalspeedinc.com/advanta...rotary-engine/
the Rotary uses oil squirters that take small metered amounts of oil and mix it into the fuel to lubricate the seals
....and of course as those apex seals wear out they burn even more oil.
Old 31-05-2018, 10:34 AM   #37
Vesper Martini
Vesper Martini's Avatar
I can only assume it would be because of their emissions.
I still don't understand why you would do it other than avoid the cost of waste disposal of the old oil.
perhaps the Trucking company was actually dumping it, their excuse was its recycled into the trucks..
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2018, 10:43 AM   #38
Dodgy bros and Black diesel https://www.youtube.com/watch?v=hTF4WEfJeuI and https://www.youtube.com/watch?v=Bl3a86MT4yM
Old 31-05-2018, 10:54 AM   #39
Vesper Martini
what a lot of K#@king around to save a few bucks and potentially destroy your engine.
Might as well pour in some used Fish n chip oil too
Old 31-05-2018, 11:21 AM   #40
More on "black diesel" here http://www.dieseltechmag.com/2014/09/oil-as-fuel and http://www.oiltofuel.com/
I know a several what I would call eccentric farmers in the WA wheat-belt were doing this in the later 80's early 90's and claimed the fuel cost savings (getting the used oil free from neighbours etc) more than made up for any reduced engine life. But many of their neighbors also had the view that they might be slowly killing themselves from the blue cloud of noxious exhaust gas that they were emitting from their tractors and wouldn't even donate their used oil for fear of complicity. It would be interesting to know if indeed their rate of terminal cancers was higher. The view I came to was if the used oil had been refined to some homogeneous standard and the diesels engines and their fuel and emission systems had been designed to use such oil it might have been practical. But it was home brew stuff on engines designed for cleaner diesel. It's probably akin to ship's bunkering oil http://www.vancouversun.com/technolo...350/story.html
Old 31-05-2018, 03:37 PM   #41
roKWiz
Cabover nut
roKWiz's Avatar
I do, It's cleaner than diesel when its filtered right.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
