Old 04-10-2006, 05:53 PM   #1
Black TE50
Needs a new home.........
Black TE50's Avatar
Default Lowered IRS
I have just replaced the OE suspension on my IRS-equipped AUII TE50 with adjustable Konis and lowered King springs.
After 1 track day at Winton, the rear shocks have smashed through the rubber boots in the top of the shock towers. : These boots were brand new.
Can anyone assist with a solution to stop this happening again?
Black TE50 is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2006, 07:43 PM   #2
TwistedEL
TwistedEL's Avatar
Didn't jack the car up from the diff did you?
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2006, 08:25 PM   #3
FTE217
T3/Sprint8
FTE217's Avatar
Unfortunately the weakest part of the AUIRS.....Strut mounts at the rear.
My previous S3XR8 after lowering her went through 3 of the bloody things.
Ford reckoned a while ago they had done a revised version but that was one of the 3.
If you still have WTY you can get it replaced but don't have the lowered coils in her at the time.
My T3 was on SSL kings when I bought her, luckily there were fine so while on a good thing I put her back to std T3 height.
There is no aftermarket urethane product done that I know of which may have longer life but to harsh imo.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 05-10-2006, 09:19 AM   #4
Black TE50
Black TE50's Avatar
I was afraid that was going to be the case.
After a bit of discussion, my spanner man is going to try using bigger washers on the top of the shocks to spread the load on the strut mounts a little wider and maybe lengthen the bump stops. I'll report back with the results - I have another track day at Phillip Island in 2 weeks.
I hope we can solve the problem - the car looks s**t hot lowered at the back.
Old 05-10-2006, 09:44 AM   #5
blackers10
blackers10's Avatar
why couldnt you just get a bracket welded up for it to replace the rubber part??
it will ride a bit harsher but in the long run it would be better?
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2006, 10:48 AM   #6
FTE217
T3/Sprint8
FTE217's Avatar
I agree they look : lowered...
Longer bump stop even less travel but for track work doesn't matter.
I am intending lowering mine a lttle more at the rear let me know how she lasts with the fix....
Daily Macan GTS
Old 05-10-2006, 11:35 AM   #7
Black TE50
Black TE50's Avatar
Yes, a possible solution. I'll wait until after the Island to see where we are at.
Old 05-10-2006, 11:37 AM   #8
blackers10
blackers10's Avatar
i was also thinking it would be stiffer so would maintain your suspension geometry etc like when using rose joints etc
Old 05-10-2006, 04:51 PM   #9
DJM83
Barra Turbo > V8
DJM83's Avatar
Could u post a pic im thinkin of lowerin mine
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
