Old 06-06-2005, 09:29 AM   #1
lewstung
Default Badges on fairmont AU
Hi, I'm thinkin of taking off a few of the badges on my fairmont ghia like the 'ghia' and '75' ones...are these easy to take off without doing damage? and are they just stuck on there with some sort of glue, or are there holes for them with little rivet things? This probably seems stupid but your help is much appreciated!
lewstung is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2005, 10:13 AM   #2
jonbays
TL40 Wagon?
Easy to do just peel them off carefully.
A delicate slit with a razor to start them peeling or prising the badge with a small screwdriver can help sometimes.
The "fairmont" badge will leave two holes!
Old 06-06-2005, 11:44 AM   #3
lewstung
...but the ghia & 75 ones won't leave holes? Thanks for your help
Old 06-06-2005, 12:03 PM   #4
jonbays
TL40 Wagon?
Correct just might leave bit of rubber behind.
Metho will make it soft and you can rub it off by hand and then polish.
Old 06-06-2005, 12:19 PM   #5
lewstung
thanks mate.. the ghia badge looks pretty shitty I reckon - so see ya later
Old 06-06-2005, 10:04 PM   #6
xr8 007
xr8 007's Avatar
a bit of heat,,,hair dryer, will soften all the glue and stuff!
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2006, 10:11 PM   #7
fairmont au
fairmont ghia au 2 wagon
hi, if you are interested in selling the ghia badges its just we upgraded the fairmont to ghia interior and how much would you want for them?
fairmont au is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2006, 11:42 PM   #8
Abacus
Life's a Gas
Abacus's Avatar
I've also heard you can start peeling off the badges by sliding a length of fishing line behind them.
They're not really reusable after they are peeled off - new ones aren't all that expensive.
Abacus is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2006, 12:23 AM   #9
mattp
mattp's Avatar
I took mine off with a hairdryer and dental floss. Worked a treat, just take it slow...
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2006, 10:41 AM   #10
ClassicAU
just on this, how do you get the sticker type logos off? i have the Classic sticker on the boot lid and am looking at going the de-badge look. do the come off with metho as well, or must they be peeled off?
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2006, 10:44 AM   #11
HLC
Audi S3
hair dryer, peel it off slowly.
Old 07-09-2006, 12:23 PM   #12
GlennBA
GlennBA's Avatar
if its a 75th anniversary ghia then it'd be a series 2 sedan, therefore the fairmont badge would be on the boot garnish. No badge you remove on an AUII/III sedan will leave holes except the blue ovals. Don't use a razor, use fishingline then wax and grease remover (prepsol) to remove the glue. I've removed all the badges off my AU and a couple off dads XR6T using this method.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2006, 12:25 PM   #13
GlennBA
GlennBA's Avatar
Pick them off carefully with your fingernails. Don't use a razor because 1 slip and your paintjob is ruined. You could use some prepsol or eucalyptus oil to help remove it easier. I just picked my intech ohc decals off using my nails and they didn't stuff the paint.
