Old 25-06-2006, 04:26 AM   #1
5speedTE
5speedTE's Avatar
Default Why do you stall on me????
Hi guys,
Ive got a AU2 5 speed, its a 6. It runs like a dream, but i recently disconected the battery and once i re-connected it the car keeps stalling on me constantly.
I have reset the computer heaps of times, i even gave up after a week of trying and took it to Ford.... They charger me $80 to clean the throttle body and reset the codes and do a re-learn...
She was all good for a complete day and the problem came back.... Its so annoying....i have to start her up again after i stop at lights, give way signs, stop sign well anyting that requires me to clutch and slow down to 30kms..
If anyone has any ideas as to what this could be please let me know. I have her booked in to ford again on Monday but if i could sort it b4 then it would be great..
Thanx guys
Jason
* 2004 BA XR8 ute
* 2006 Territory Ghia Turbo
* 2002 VX SS heavily modified
* 2010 BMW 320i M Sport
5speedTE is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2006, 12:34 AM   #2
TE-50
FTETE50
Ive just had the same problem with my car, i cleaned my throttle body, removed and cleaned idle speed control valve, then reset base idle speed. the computer will relearn, it just takes a while
TE-50 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2006, 11:24 AM   #3
lemkas
i just had the same problem too. Just gave the car a service (as it was due anyway) and reset the base idle. been running fine since.
lemkas is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2006, 04:32 PM   #4
JC
JC's Avatar
Clean ISC is a good idea.
TE-50/lemkas, How do you reset base idle?
Ford Performance Club ACT
Old 30-06-2006, 12:34 AM   #5
5speedTE
5speedTE's Avatar
ok, how do you reset the base idle?
* 2004 BA XR8 ute
Old 30-06-2006, 09:29 AM   #6
2002auxr6
Drunk!
2002auxr6's Avatar
YEAH HOW DO U RESET THE BASe IDLE
2002auxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2006, 01:33 PM   #7
FS5
with the engine turned off ,disconnect the idle speed contol valve .then get a 0.75 mm feeler gauge and place it between the idle screw and throttle body.start up your engine and it should be idling between 700/800 rpm.if it isn't ajust the idle srew accordingly .once you get it set right turn off your engine and reconnect the idle speed valve .restart your engine and away you go.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2006, 02:47 PM   #8
2002auxr6
Drunk!
2002auxr6's Avatar
is the valve on the throttle body and does it have a red cap on it
