Old 18-06-2006, 03:46 PM   #1
RspecAU
BA GT-P Owner
RspecAU's Avatar
Default IRS axel broken
While driving the AU today I heard a thumping noise from the left in the rear of the car...i'm guessing that it has broken the axel joint/s. anyone know how much this is going to cost and is it an easy job to fix?
Cheers RspecAU (Mark)
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
299.5 rwkw's 12.74 @108mph ON MT's
ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
RspecAU is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 03:53 PM   #2
XA-Coupe
Mark,
having had a broken axle in a BA IRS I can pretty well assure you that you haven't broken it. LSD or not, mine had no drive when it went.
Might pay to rip the wheel off and have a look.
XA-Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 04:01 PM   #3
RspecAU
BA GT-P Owner
RspecAU's Avatar
Thanks for that....thats the best news i've had all day.
BUILD NUMBER 006
Old 18-06-2006, 04:05 PM   #4
XA-Coupe
Don't say that in case it's something more expensive :
Old 18-06-2006, 04:49 PM   #5
RspecAU
BA GT-P Owner
RspecAU's Avatar
and knowing the way my luck had going lately you could be right :
BUILD NUMBER 006
Old 18-06-2006, 04:52 PM   #6
Casper
Contributing Member
Casper's Avatar
Its your shock rubber.. its finally let go completely. Pull the kiddy seat oud, drop the rear seat and have a look behind the panel.. its probably got half a shock absorber poking through it.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 05:39 PM   #7
Bucknaked
Bucknaked's Avatar
I had the thumping noise in mine. It was the shock mounts. Had them replace and it was as good as new.
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 18-06-2006, 06:07 PM   #8
RspecAU
BA GT-P Owner
RspecAU's Avatar
god i hope thats all it but there was a lot of what felt like wheel wobble. Want be able to nothing till tomorrow now. Thanks guys
BUILD NUMBER 006
Old 18-06-2006, 08:50 PM   #9
blackers10
blackers10's Avatar
whats a shock mount worth??
im presuming its the top part of the strut that is rubber??
with the metal bit in the middle
i carved the guts out of 2 of these..(all the rubber)
the metal piece in the middle is an hour glass shape 1 end is fatter than the other and only comes out 1 way(to prevent it falling ALL the way out i guess)
Old 18-06-2006, 09:25 PM   #10
RspecAU
BA GT-P Owner
RspecAU's Avatar
I paid $87 for the left i got....I just need some time to put them in
BUILD NUMBER 006
Old 19-06-2006, 04:14 PM   #11
janek
Ripping it up
lol... ive snapped an axle too... if your axle goes, you dont. and good luck removing the stub out of the hub assembly... it gets very expensive :S
janek is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 02:47 AM   #12
RspecAU
BA GT-P Owner
RspecAU's Avatar
After getting the wheel off and having a close look at what is wrong I found that the rotor had a lot of movment in it. I removed the hub and found that the bearing were shot which has also stuffed the hub. I have tracked down a second hand hub assembly for $275 hate to see what a new is worth.
Cheers Mark
BUILD NUMBER 006
Old 20-06-2006, 02:56 AM   #13
blackers10
blackers10's Avatar
toe adjustment rod on an IRS falcon/fairlane is $700 from ford 170 or 190(cant remember) from FTG our sponsors
all i want to know for mine is how to change the bushes for the rear upper and lower control arms
Old 20-06-2006, 12:18 PM   #14
RspecAU
BA GT-P Owner
RspecAU's Avatar
All mine look good all tho i didn't get to look at the inner bushes but i would say they would be the one that you woule need to have pressed out. The outer bushes look easy enough to change but then again things can look easy.
BUILD NUMBER 006
Old 20-06-2006, 12:29 PM   #15
blackers10
blackers10's Avatar
yeah im talking about the outters
does anybody know
if when the toe adjustment rod is removed.. does the entire rear hub become able to turn like the front wheel ie you can just wiggle it left and right as tho it has rear wheel steering?
or is my bushes just SHAGGED!
thanks guys
Old 20-06-2006, 09:09 PM   #16
RspecAU
BA GT-P Owner
RspecAU's Avatar
Well the AU is going again but not after a few problems, while giving it a test run the halfshaft poped out of the diff. I must of pulled it out with out knowing. I got it back and fixed that but i will be getting it at closly real soon. A big thanks to G&D for lending me a 35mm socket to undo/tighten the big nut on the end of the axel thank guys i would of been stuffed without that.
Cheers Mark
BUILD NUMBER 006
