Old 05-06-2006, 10:09 AM   #1
39ClevoUte
39ClevoUte's Avatar
Default K&N Hot wire damage???
OK
Bought a K&N and fitted. Seems the bees knees
Here's a question though... on their web site they mention manufacturers giving warrenty issues on MAF sensors....which I assume is the hot wire.
Whilst they defend their position on this, it does make a little sense
ie (my thoughts) little droplets of oil landing on the hot wire, getting burnt and causing it to stay hotter than it should be, it thinks less air going past and leans out motor. K&N suggest cleaning if this happens but claim not to be responsible, OK.
My question... anyone experienced this????
Warning for not over oiling???
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2006, 02:50 PM   #2
qwigybo
hunting 300kw's
qwigybo's Avatar
never had a problem with mine
qwigybo is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2006, 10:32 AM   #3
quest
quest's Avatar
Have seen many here
K & N say customer must have over oiled the element after cleaning to cause the problem
Bottom line is no warranty!
quest is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2006, 10:52 AM   #4
39ClevoUte
39ClevoUte's Avatar
mmmm interesting
Old 06-06-2006, 02:08 PM   #5
kooky
WRX terrorist
kooky's Avatar
Just be careful when re-oiling, light coat let it 'wick-in' (20 mins or so) then add another light spray. WRX's are prone to MAF sensor failure in normal conditions let alone oiled filters, having said that I just cleaned and re-oiled mine last weekend no dramas if you arent too heavy handed with the spray
: MY-03 STi :
kooky is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2006, 04:58 PM   #6
39ClevoUte
39ClevoUte's Avatar
Thanks Kooky
Old 06-06-2006, 07:27 PM   #7
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
another alternative to a k&N if your worried is you could buy a 2 stage uniFilter and only oil the outer layer.
I am not starting a one filter is better thank the other argument as it is personal preference.
1969 XW Fairmont-1999 explorer 5.0- comp cam XE270HR, 9.8:1comp, Ported Gt40p, Ford Racing oil Cooler, EL V8 radiator & thermo's,
Fuel/intake -XR6T injectors, 255 LPH intank pump, 4" intake, HaltechE11v2 Exhaust-custom Tri-Y headers, Twin 2.5" HiFlo Cats, duel 2.5" exh Driveline-close ratio 4spd, 9" LSD, 300mm AU XR8 fr, XC rear, ZH Fairlane Mas/Cyl & Booster
Project car: http://www.fordforums.com.au/showthread.php?t=21641
EFIwindsor is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2006, 08:57 PM   #8
39ClevoUte
39ClevoUte's Avatar
Ok will check that out as well. Thanks EFI
Old 07-06-2006, 09:39 PM   #9
ebxr8240
Performance moderator
ebxr8240's Avatar
Its not that it renders the meter useless ..
Just clean it if there's any issues...
It's not exactly the oil.. Its the bum fluff that sticks to the oil on hot wire...
Daily driver GTE FG..
