Old 07-06-2006, 08:06 PM   #1
alxdup
Unhappy eb 4.0 into xf ute what the?
hi just new to the forum, right now i have my eb motor on the engine crane hanging in the engine bay of my xf ute with standard eb engine mounts and sump i've been told this will go straight in but the sump hits the sway bar b4 the mounts line up, deos any1 know which sump or mounts i should be using???????????
alxdup is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2006, 08:33 PM   #2
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Try XG ute mounts and XG ute swaybar. The XG was basically an EB engined XF!
These mounts tilt the engine slightly for greater clearance around the inlet manifold and for the heater hoses. The XG swaybar is different to the XF. The EB sump should be used.
Welcome to the forums, like your enthusiasm, but try a bit of research before you have the engine hanging off a crane :
Raptor is offline   Reply With Quote Multi-Quote with this Post
