Old 07-05-2006, 10:31 AM   #1
Falcon Freak
Falcon Freak's Avatar
Default Relationship between power and torque
I found this article which may be of interest. Many people do not understand how these two relate to each other.
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 02:48 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
As the saying goes power sells cars torque makes them go
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 04:22 PM   #3
Grechie
Grechie's Avatar
i think i herd john bowe say that..., "kilowatts sell cars, torque wins races"
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 04:33 PM   #4
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Everyone was suprised when my old man pulled only 190rwhp out of his 289 in the mustang.
Everyone said it went so hard for so little power. But yeah then we had a little look at the torque read out.
750nm Torque is what got the old girl goin.
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 06:50 PM   #5
Wokkas
Agreed, but let's not forget that "power" IS potential torque.
It's more about WHERE the torque is in the rev range.
Wokkas is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 12:58 PM   #6
chevypower
chevypower's Avatar
Well all race cars should have big Cummins diesels then. Power is more directly related to acceleration than torque is, torque affects driveability, and twisting ability on the axles, but not acceleration directly. TO get a better idea, just look at extremes.. imagine how good a 30kw 800Nm NA diesel would perform against a 300kw 200Nm rice burner would perform.. The kw's is what wins the races
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 01:05 PM   #7
superroo
You can't stop the signal
superroo's Avatar
The simple way to understand this is,
torque is the amount of work done
Horsepower/kilowats, is the rate at which work is done
Old 08-05-2006, 02:31 PM   #8
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
Twas "Horsepower sells engines... Torque wins races!!"
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 02:41 PM   #9
chevypower
chevypower's Avatar
torque is simply force or weight (newtons, pounds, kg etc) over distance (feet, meters etc) if you have a a wrench with a 1m handle and you use 2 newtons of force on the end of the handle, you have 2Nm of torque. if you extend the handle to 2m, and you only use 1 Newton of force you also have 2Nm of torque -as i said, relates to twisting ability or how easy it is to undo the nut (turn the rear axle) - nothing to do with how quickly you turn the nut - that is power.
Old 08-05-2006, 09:30 PM   #10
TEaaron
TEaaron's Avatar
I see it as torque moves the car, power makes it rev.
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 01:04 PM   #11
fast66
Hmmm, 750Nm??? Havent forgoten to convert back to crank torque figures there have we? Whats the diff ratio, and what gear was it measured in?
fast66 is offline   Reply With Quote Multi-Quote with this Post
