#32 | ||
When it comes to power usage, you have to factor in time. Say you put 2 things side by side, both draw 2400w or 10 amps yet one does the job in two thirds or half the time, which is more convenient and uses less power?
Same with inductance cook tops. They heat up fast and take a lot less time to heat a pot. Same cooking time vs regular snail electric cooktop, but a snail cook top takes a lot longer to heat up. So its a time vs wattage thing. If the thing uses slightly more but does the same job a lot faster, it still is cheaper to run. |
#33 | ||
#34 | |||
Gpos in kitchens tend to be the ones that melt first from my experience as an electrician. |
2 users like this post: |
#35 | |||
Checked the air fryer, it’s a Philips XL5000 series rated on the label at 2kW neat. |
#36 | ||
Cabover nut
Now go out and try all this on a 15amp powered site with your 30amp double corded caravan.
#37 | ||
Why am I now getting the Ninja air fryer appearing all over my social media feeds??!!
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#38 | ||
I’m not. Endless adverts for Stan here, and I don’t watch any TV at all!
