Old 07-01-2025, 10:54 PM   #1
Cool Simple Key Rings
Can anyone recommend a brand or source of exactly that?
Key rings of similar size to that supplied with many Oz Fords. Non corroding. Sturdy. No tags or gimmicks or promo doodads, just plain key rings in nickel or chrome plate, or stainless.
Old 08-01-2025, 01:07 AM   #2
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Default Re: Simple Key Rings
You mean just the ring itself ? Split ring I think they are called.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2025, 04:39 AM   #3
Yes, just the ring.
Old 08-01-2025, 06:53 AM   #4
Fatbob103
Millions of them at bunnings........
Fatbob103 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2025, 07:05 AM   #5
Bunnings quality usually disappoints; I’m hoping someone has found a particular item they are pleased with.
Originally I thought places like Whitworths might have had simple rings in stainless, but they have only carabiners and rings with buoyancy aids. I mention stainless because most electroplating on smaller, cheaper items is now rubbish thanks to its country of origin.
Old 08-01-2025, 07:45 AM   #6
Peter B - CV8
Mr Minit type stores ??
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2025, 08:10 AM   #7
It could come to that. Looking online I can get 25mm stainless (most common size from my measuring) for $40/100 - but I don’t necessarily see that quantity as a challenge to increase the size of my fleet. ;-)
Old 08-01-2025, 11:55 AM   #8
AMB
Yeah, cheap ones are made of thin gauge wire and don’t have much spring in them, they easily deform/lose their spring. Good quality ones are thick gauge, at least 1 mm diameter wire at a guess, and heaps of spring in them, takes a bit of force to open them up.
Shoe repairer/key cutter should have them. Otherwise try anywhere that sells keys rings with whatever silly large motif on them, remove the chunky ring. Just looked at supercheap, they have heaps of them, some of them look like they got a chunky ring.
For a really chunky high quality one try a camping fishing store. edit. Just had a look at that large camping/fishing franchise, camping ones are quality, fishing ones probably even better for corrosion. Same for yachting saling shop, they should have split rings and you can be sure its high grade stainless.
Old 08-01-2025, 12:06 PM   #9
Aldi also sometimes have them as an assortment in special buys. Their quality seems OK.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 08-01-2025, 02:32 PM   #10
These might be okay; they have a good selection of sizes, but the exchange rate and international shipping might make it uneconomical - at least 50% more than your $40 per 100 units:
https://berkeleypoint.com/products/h...plitrings.html
These look good for the toolkit:
https://berkeleypoint.com/products/t...ng_pliers.html
Old 08-01-2025, 02:43 PM   #11
Itsme
Experienced Member
Itsme's Avatar
Officeworks will be the go, click the link.
https://www.officeworks.com.au/shop/...rtBy=bestmatch
