Hello I'm new.
Does anyone have any service/workshop manuals for a 2nd gen festiva? and if so would you be willing to share ? All I want to do is remove panels so I can get to the wiring at the back of he cd player. Any help would be great. |
I've got the 1986-1993 manual so I'm not sure whether that's what you are calling 2nd generation.
You don't need to remove the instrument fascia to get the head unit out but there is a special tool (P/N 49 D066 801) which is a pair of U-shaped prongs that fit into small holes on the front of the unit - you could probably make one as the prongs just release small tabs when you hold them apart. This will give you access to the plugs and wiring at the rear of the unit. ![]()
Thanks mate. I have a 94, I managed to get the aftermarket unit out, of course the previous owner spliced.into the wiring loom so it's a total mess back there! I'm intending to install a android double din head unit. Wish me luck! My mechanic mate is going to check his shop for a service manual....if I get my hands on one i'll be sure to post it here.
I have the 94-2004 manual as well if it's of any help.
Here is the exploded diagram of the instrument panel trim and associated bits. ![]() The instructions aren't that bad: Centre Panel (12 in diagram) Remove the 7 retaining screws Pull the assembly forward to remove it Disconnect the lighter socket Side Panel (10 in diagram) Pull forward to remove (it has 4 hooks and a couple of pins to retain it)
Mate you are an actual legend !! That's exactly what I was hoping for, looked everywhere online. Yeah if you could share that 94-2004 manual that would be awesome
Love to get my hands on the festiva manual. my son has a 1998 festiva. and I do not know where to find one !
#8 | |||
https://www.computeroutpost.com.au/l...s=ford+festiva Last edited by WQfiesta; 09-10-2024 at 05:47 AM. Reason: added info |
