Old 11-08-2024, 09:31 PM   #241
asimplelife
mechanical novice hopeful
Default Re: 2001 AUII ute immobilizer problems
Originally Posted by dollars View Post
Regarding water leak did have a leak, on the drivers side, from the under windscreen wiper motor. “Repaired” a few months ago. Dry cabin since then.
Apologies for going OT.
But where was your water leak, how did you find it, and how did you fix it?
I've got at least 3 AU's with leaks to find and fix...and am looking for some inspiration to get started.
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2024, 01:43 PM   #242
dollars
@ASL My water leak was window wiper motor support bracket. Posted on forum and suggested problem was hairline cracks under support bracket. Repair was to remove wiper assembly then silastic around each support bracket. Cheer$
PS sorry for the late reply didn’t see your latest post
dollars is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2024, 02:00 PM   #243
asimplelife
Thanks for that. Should have thought to look for your other posts
