Old 19-08-2018, 09:34 PM   #1
Juliannailujjulian
Default Seats FG between 08 and 12. Will they fit?
Hey guys,
I tried to find some info on this but couldn't figure it our.
I have 08 XR8 Ute. Hoping to install the seats from a 12 XR6 Series 2 Sedan into my ute.
Does anyone know if this will be a straight swap?
As always, thank you in advance,
Julian
Juliannailujjulian is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2018, 04:27 AM   #2
happy1
Default Re: Seats FG between 08 and 12. Will they fit?
Hi,
The utes usually have seats that can flip forward, (in order to put items behind the seats)
If you don't care about that feature, and can manage with sliding the seats on its rails and adjusting the back rest forward then the sedan seats should fit in the ute.
Some high models have electric motors in the seats. XR models usually don't have these.
If you are fitting electric seats to a vehicle without them, you will need to patch in wiring for the power supply etc.
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2018, 07:52 PM   #3
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
The airbag connector is the biggest problem...make sure it is the same...I am not up on utes, but in 08 they might not have had them even?
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2018, 08:35 PM   #4
Giant Cranium
PURSUIT 250
Giant Cranium's Avatar
you can swap the foam and fabric from any sedan also onto your ute frames, took me 45 mins per seat bolt out to back in.
Giant Cranium is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2018, 09:07 PM   #5
Giant Cranium
PURSUIT 250
The seats just disassemble with a socket set the the leather pulls off the foams then the foam slips off. Each detail on the seat has a corresponding trench and Velcro on the foam.
Gt leather and foams (mine were crushed) onto Ute frames
Old 20-08-2018, 09:53 PM   #6
gossy
CLEVO POWERED
gossy's Avatar
Giant Cranium, can your Driver see over the steering wheel, he looks a tad short?
gossy is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2018, 09:12 AM   #7
Juliannailujjulian
Thanks for the help guys!
Really appreciate you guys taking the time
Old 08-09-2023, 07:44 PM   #8
DirtyFG
Exclamation Re: Seats FG between 08 and 12. Will they fit?
Cranium thats phenomenal. where on earth did you source GT leather and foams???? love your work.
DirtyFG is offline   Reply With Quote Multi-Quote with this Post
