Dismantling / Parting of Vehicles Specifically for largely whole vehicles being dismantled for parts. |
22-02-2023, 01:01 AM | #1 | ||
praek tih kl jo kr
Dismantling Sales Form
State : W.A. -Atwell Model : PX1 Ranger XLT Year : 2014 Interior Parts : Some Exterior Parts / Panels : 1 RHR Door Wheels : No Engine : Yes but not running Transmission : Manual 6 speed Other Driveline Parts : Yes Other relevant information. The left over parts from my 2.2 to 3.2 conversion I pretty much only have the parts listed below at the moment, I will add to the list as I go through what I have. I have a 2.2 short motor with cylinder head suit rebuild (piston failure) 6 speed manual gearbox (pin type) Transfer case Front diff / Suspension parts steering rack 2.2 Turbo clutch and flywheel 2.2 fan shroud full rubber floor from Crew cab XL interior sun visors Passenger side window mechs RH rear door complete 2.2 engine harness heater core heater fan 2.2 front cat pipe handbrake handle ABS unit Power steering pump Air conditioner pump Full ECU, BCM, ignition with key, instrument cluster and lock set for 2.2 auto ECU suit repair for 3.2 manual (has 1 cracked chip), BCM, instrument cluster and key chip to suit same vehicle Open to negotiation, but as the wreck was not free, I wont be giving the parts away If you need any pictures of any other parts just PM me , local pick up would be great, but I can wrap and post if needed. |
26-02-2023, 03:03 PM | #2 | ||
praek tih kl jo kr
doh wrong post
09-03-2023, 08:59 PM | #3 | ||
praek tih kl jo kr
Sold
Front diff RH CV shaft Transfer shift mechanism |
