Old 09-01-2023, 01:22 PM   #1
Trevor 57
Trevor 57's Avatar
Default Cummins combat diesel engine - interesting design
I know it is nearly 5 years old, but I am not sure if many have seen it
Flat 4cylinder, 1000bhp, about twice that in torque, two massive turbos, a supercharger, no valves, no cylinder heads, and it's a diesel.
It's got 8 pistons. And two crankshafts. Despite being a 4cylinder. Yes, it's an opposed piston engine, ie two pistons per cylinder facing each other.
This is a new Cummins engine designed for military use, and it's pretty badass.
It's 14.3ltr, so 1000bhp doesn't sound a lot for that capacity, but for a super low revving diesel that's intended to work for literally ever at full load, that's a lot- Most OEM 14ltr diesels make under 600bhp. And thanks to only 4cyl and no cylinder heads, it's relatively small too.
It's a 2stroke engine, so no valves, and the inlet and exhaust ports are opened by the pistons literally uncovering the holes on the sides of the cylinder walls- Much like ports on a rotary engine for anyone not used to 2stroke engines.
The turbos are twin Holset HE500 VGT turbos, which are 1000bhp+ capable units if pushed to their limits- Beasts.
The mix of 2stroke, supercharged, twin turbo, flat 4, and opposed piston, means this thing should sound pretty insane too.
Rather than me explain it all here, watch the video as the last parts are animations that shows exactly how the cranks are geared together and how the inlet and exhaust port setup works.
https://youtu.be/OfBB6uNkYKM
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2023, 01:25 PM   #2
roKWiz
Cabover nut
roKWiz's Avatar
Default Re: Cummins combat diesel engine - interesting design
They brought that out at the same time they celebrated the VT903's 50th year of manufacture. (their other primary combat engine)
Old 09-01-2023, 04:07 PM   #3
GASWAGON
Very impressive indeed.
Alot different to previous NT/N14 and Signature 600 Cummins!
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2023, 04:47 PM   #4
XR Martin
XR Martin's Avatar
There's a reason it's for military use - no emissions regulations.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 09-01-2023, 07:27 PM   #5
boss351290
When your fighting for life and someone is trying to kill you…. Do you care about emissions????
boss351290 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2023, 08:43 PM   #6
XR Martin
XR Martin's Avatar
I'm just saying the engine will never make it to civilian vehicle use due to emissions laws.
It's an impressive engine for off-road use.
Old 10-01-2023, 08:54 AM   #7
PooDog
PooDog's Avatar
[Modern day Commer knocker motor lol
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 10-01-2023, 09:22 AM   #8
Old 10-01-2023, 05:05 PM   #9
jpd80
jpd80's Avatar
A lot of the yank military runs on a common jet fuel, not diesel
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2023, 05:15 PM   #10
Trevor 57
Trevor 57's Avatar
So clean kero?
Old 10-01-2023, 06:24 PM   #11
jpd80
jpd80's Avatar
So clean kero?
JP-8 is similar to commercial aviation fuel with some extra additives
Most of the tanks have turbines and Diesel engines can run on it too.
Old 11-01-2023, 03:20 PM   #12
burnz
VFII SS UTE
burnz's Avatar
So clean kero?
i don't think it matters trev, it's still oil.
slightly less energy per liter.
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2023, 03:27 PM   #13
burnz
VFII SS UTE
burnz's Avatar
Napier Deltic train engine.
https://en.wikipedia.org/wiki/Napier_Deltic
https://www.youtube.com/watch?v=jPUy9a3xi4w
GO SOUTHS
Old 11-01-2023, 03:28 PM   #14
Bossxr8
Peter Car
Bossxr8's Avatar
The engine in the M1 Abrams can pretty much run on anything resembling a type of fuel.
Old 11-01-2023, 03:42 PM   #15
roKWiz
Cabover nut
roKWiz's Avatar
Originally Posted by burnz View Post
One of best sounding diesels. imo.
Old 11-01-2023, 06:39 PM   #16
jpd80
jpd80's Avatar
Because it’s a gas turbine…
Old 11-01-2023, 06:42 PM   #17
jpd80
jpd80's Avatar
Nice engine design but it used to oil up badly
Old 12-01-2023, 11:58 AM   #18
Bossxr8
Peter Car
Bossxr8's Avatar
Correct. Supposed to be a massive fuel guzzler as well, with a fairly limited range for a tank. The supply lines would need to be well in check to keep them fuelled up.
Old 12-01-2023, 01:58 PM   #19
roKWiz
Cabover nut
roKWiz's Avatar
Exactly the same reason both Kenworth in the 50's and Ford in the 60's gave up on gas turbines.
Quoted from trucksplanet site......."Gas turbine powered Kenworth had crossed the United States from north to south, and then worked briefly in commercial traffic plying on the western coast, between Seattle and Los Angeles, the tests, alas, failed. First of all, the trip lasted five or six hours longer than with conventional diesel engine: a gas turbine powered truck was accelerated slowly, heavily smoked, while squeezing the clutch pedal was a real torture (despite the fact that even the conventional old "Americans" have vere tight clutch). But the main problem was that the consumption of turbine was equaled a mile per gallon, or 235 l/100 km!"
Makes the Cummins look like a fuel pincher.
Old 12-01-2023, 02:24 PM   #20
Bossxr8
Peter Car
Bossxr8's Avatar
I’m pretty sure Chrysler was the furtherest down the road with gas turbines. I think they actually leased some out to the public? But yeah the economy was poor, and i think they generated a lot of heat as well, so they eventually gave up.
Old 12-01-2023, 04:54 PM   #21
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
