Old 18-08-2021, 06:58 AM   #1
gbull068
Default Electronic Distributor
Hello
I bought a 250 crossflow 6 from a wreckers a couple of months back which i have put in a boat , it came with an electronic Distributor and no coil, the wires where cut from the coil. so what I'm left with
brown
brown/black
yellow/green
I'm guessing the Brown is +
and the brown /black is _
not to sure what the yellow/green is
can someone please give some advise
cheers
Garry
gbull068 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2021, 08:13 PM   #2
66 coupe
around the place
66 coupe's Avatar
Default Re: Electronic Distributor
is it sn XF EST distributor? post up a pic of what you have....
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2021, 06:42 AM   #3
gbull068
Hi Coupe
same as this one
as attached
cheers
Garry
Old 19-08-2021, 07:52 AM   #4
Dr Terry
As far as I can see from those pics, that dissy is an XF EST unit & as such doesn't do much on its own. It is meant to be used with an EST control module (ECU). All it has inside is a hall effect pick-up & no method of advance.
For your boat motor you need a proper electronic dissy out of an alloy head XD, an XE or a leaded XF (pre-1986). It is a complete dissy with full advance mechanism & control module, it just needs an ignition coil & you are right to go.
Dr Terry.
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2021, 09:35 AM   #5
gbull068
Thanks Doc
that's all i needed to hear lol ....more money god dam it
cheers
Garry
Old 19-08-2021, 11:48 AM   #6
gbull068
thanks for the advise
just wondering if will this one fit
https://www.ebay.com.au/itm/224224826588
Old 19-08-2021, 01:20 PM   #7
Dr Terry
Yeah, that'll do the job.
Dr Terry
Old 20-08-2021, 08:54 AM   #8
gbull068
Thanks Doc
appreciate the advise given
cheers
Garry
Old 20-08-2021, 11:47 AM   #9
66 coupe
around the place
66 coupe's Avatar
mate just be careful with those chinese ebay cr@p ones. you will either have issues with the module failing, or the gear chomping the cam.. its very common especially on the singlecam engines cheap dissy costs engines after a few months.
personally id get onto a ford wrecker and see if theres any genuine bosch/motorcraft ones around and get hold of one and rebuild it if needed. I probably had a box full of them, but got rid of all the junk that never got used :(
