Old 15-02-2005, 10:16 PM   #1
wulos
Forum Director
wulos's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind-the-scenes effort. Technical Contributor: For members who share their technical expertise. - Issue reason: For his advice, tips/tricks in the Art and Photography section of the Forum.
Default What's it worth????
As the title suggests... What should I charge for the following???? The print is an 8x12" in a 400x500mm frame. As you can see from the pic it is not signed.....
I need to state that in light of the fact that the sbr logo is a copyright protected image - I will be removing that element from any print I prepare(including that one) :( shame works well - but it ain't right to steal other peoples work....
The caption will be mounted in the centre bottom
Last edited by wulos; 15-02-2005 at 10:48 PM. Reason: *removed sbr logo from pic paragraph added*
wulos is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2005, 02:10 AM   #2
JADED6
V8 Ghia & BF2 XR6 + Wagon
JADED6's Avatar
Frame is to big for the print. Pic needs to be the dominant part as far as area goes.
Either get a smaller frame or work on the matting a bit (ie, another layer around the outside, black etc)
Who took the pic? you? Like it.
If the Ingall write up is on paper (consider this if you want) you can buy small brass plates that stick on to photoframes (even under the glass) and get them engraved. doesn't cost a whole lot and looks great.
JADED6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2005, 06:02 PM   #3
XP6
Formerly ST170ish
XP6's Avatar
If you want some custom wood frames made give me a yell, got heaps of baltic pine which comes up real nice.
XP6 is offline   Reply With Quote Multi-Quote with this Post
