Old 23-03-2006, 10:19 AM   #1
BROCKYB8
YEAH IT IS A FORD
BROCKYB8's Avatar
Exclamation DIFFS in EA BROCK
I have just recently started some work on the BRock and i am sick of the single spinner . I have been told by so many people what i should do but i am unsure what i can do . What gears for a lsd does anyone suggests. As being a EA 5 speed it has a really long first gear then many of the xr6 in eb to ed
. Hope u can help
Thnaks
BROCKYB8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2006, 10:23 AM   #2
EA2BA
PM me if you want
EA2BA's Avatar
You can get nearly any gear ratio you want in LSD, up to the 3.45 there are off the shelf speedo gears avaliable to correct the speedo, anything else will need an electronic speedo corrector installed.
Old 24-03-2006, 01:16 AM   #3
BROCKYB8
YEAH IT IS A FORD
BROCKYB8's Avatar
anysuggestion on what gears i should try to run with it so many people been tell ing me so many things . Would like to know what does what with the gear ratio . I have been told 3.7 or a 345 would be good
thanks
Old 24-03-2006, 01:22 AM   #4
RavenLS1
ive got a 3.23 and it pulls like a train.ive also got a EA box in mine, first gear is useless if you plant it(just spins both wheels).
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 01:25 AM   #5
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
. Hope u can help
Thnaks
matey, EA's are notorious for their extremely short 1st gears...
im personally running 3.73s at the moment which is nice and high...
depends what you want to get out of it?
off memory the brocks ran standard diff ratios of the model purchased before the conversion...
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 01:27 AM   #6
RavenLS1
What do you get out of first gear, out of curiosity?
Old 24-03-2006, 01:35 AM   #7
santoitaliano
BF F6, APV SR3900
40-50 ks..
Santo
Daily:
Bluepower enhanced.
Old 24-03-2006, 01:52 AM   #8
BROCKYB8
YEAH IT IS A FORD
BROCKYB8's Avatar
REv it only to 4 and half i get about 65 but was told that its pretty high for EA .
Apparently they ran a 292 i think do not qopute me
im looking at gettinga lsd in next few weeks . just need advice.
Im not a really high speed person like over 150
but i dont mine gettign up and goin quickly
Old 24-03-2006, 02:01 AM   #9
santoitaliano
BF F6, APV SR3900
292 is a pretty low ratio diff! hence why your getting such speeds out of 1st! EA 5spd with a 3.23 diff in it will be doing exactly 52km/h at 5000rpm
Santo
Daily:
Bluepower enhanced.
Old 24-03-2006, 09:49 AM   #10
BROCKYB8
YEAH IT IS A FORD
BROCKYB8's Avatar
well are u suggesting to go up to a 3.7 or higher what are uur thoughs on it and secondly where are good places to go to get this.
Thnaks
Old 24-03-2006, 11:04 AM   #11
BI6TIM
SnortPerformance.com
Hey brocky, the ea's had a 3.5/1 ratio first gear from the factory as opposed to a 3.25/1 first gear in the ebII and ed. As for your diff it will have 2.92 gears in it and it will be a two pinion, 25 spline diff. what you want is a 4pinion, 28 spline diff out of an EBII or ED they are much stronger. Also i would suggest going for the 3.45 diff gears as they are a nice compromise between acceleration and highway cruising capibilities, I have just put 3.45 diff gears in my ED 5M and am pretty happy with it! As for diff shops, where exactly is Patterson Lakes?
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
