Old 26-02-2017, 05:04 PM   #1
KiwiKilda
Default Falcon AU Window Actuators
Pain in the A Passenger Front Window is not going up
Can't get a new actuator until next week some time
Repco have one at the Warehouse but at 10-4pm
too late to get it
Got the Door Trim off is there a way to force the window
up so I can drive
Weather forecast is good but we know Melbourne
Where is the best place to get one
200+ is OTT for a window actuator
Can I get the window permanently up so at least I can
drive if so
How ??? Please Help
KiwiKilda is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2017, 01:26 PM   #2
Mechan1k
Mechan1k's Avatar
Default Re: Falcon AU Window Actuators
Have moved thread to the AU section where you will get a better answer.
Old 11-03-2017, 02:02 PM   #3
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
I can supply one in Melbourne if you're stuck and provided it's electric not manual. PM if interested.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2018, 01:47 AM   #4
rowan194
I know this is an old thread, but....... for future reference, you can cut the winder cable (not any electrics!) to free the window, then prop it up with a piece of wood between the bottom of the glass and the bottom of the door.
I used some scrap wood that I cut to length (really just eyeballing it), then held it in place with a large cable tie between a couple of holes in the door frame.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2018, 01:38 PM   #5
Vortex-98
Vortex-98's Avatar
Another trick is if you have a battery charger ,is to remove door trim ,locate the electrical loom for the windows switch an see which wires move up then reverse polarity to wind them down us IJSjng just the battery charger to supply the power
An the window wiring loom from the interior switch goes to the window loom to the battery
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B]
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
