Old 20-08-2017, 08:33 AM   #1
zeuss000
Default Focus randomly not starting
Howdy Folks, I am having an issue with the missus 04 Focus. Sometimes it will not start, turn the key and nothing happens, no click, the lights don't dim at all, just nothing. I know the battery is fine and the battery terminals are clean and tight. Usually if it just sits for a while (1/2 hour) it will start fine. It is very random, the car gets used several times a day and this only happens once a month or so. Any suggestions? other than this problem it runs really well.
Ed
zeuss000 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2017, 09:02 AM   #2
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Default Re: Focus randomly not starting
Ignition switch seems to be common cause for this.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2017, 09:08 AM   #3
russellw
Chairman & Administrator
russellw's Avatar
Sounds more like something with the ignition barrel. I've not heard of it with Focus particularly but if it gets started multiple times a day that is probably contributing.
Having said that, it should gradually get worse if that is the cause.
Russ
Observatio Facta Rotae
Old 20-08-2017, 12:30 PM   #4
zeuss000
Thank you very much for the advice guys, Makes it really difficult to diagnose when it is so intermittent but yes i am also thinking ignition switch issues.
Maybe i should wire in the spare starter button i have for my BA-GT (or not)
Ed
