Old 12-05-2017, 08:02 AM   #1
Holty
Default Are Fg - au mag wheels compatible?
Hi the i have a AU falcon and i was wondering if a set of mag wheels of a 2010 fg will fit they are 225/55r16 i head it might have a different offset thanks if anyone can help 👍
Holty is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2017, 08:24 AM   #2
Gothefalcon
FAWD - No Boundaries
Gothefalcon's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: He takes long trips in his AWD Falcon & where ever he goes he sets out to meet forum members at various destinations. He does this without expectation of any sort. I have had the pleasure of spending time with Dhru on two of his separate trips and his gre Technical Contributor: For members who share their technical expertise. - Issue reason: The excellent write ups in your BF AWD Falcon Wagon thread
Default Re: Are Fg - au mag wheels compatible?
AU - FGX share the same offset.
D
View My Build thread
22 DJR Shell V-Power Mustang Eskymobile (my first EV)
07 BF2 AWD Falcon Wagon (Daily driver)
04 BA Falcon 1Tonner Ute (New Project)
03 BA Falcon Wagon (Spare)
98 NL Fairlane Ghia V8 (Weekend cruiser)
70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
Gothefalcon is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2017, 08:48 AM   #3
Holty
Ok thanks i was just told the fg wad different be a couple of mm but will still fit thanks for the reply
Old 12-05-2017, 09:04 AM   #4
Gothefalcon
The FG - FGX have a wider track than AU - BF3... but this is due to suspension changes etc.
Depending on what rim/tyre combo you end up using, the overall diameter may be different to what you have now (possibly !??) so you may also need to change the Speedo cog in the AU, to suit !??
D
Old 12-05-2017, 11:43 AM   #5
Holty
Ok thanks size is around the same ;👍
Old 12-05-2017, 05:53 PM   #6
OzriderXR8
OzriderXR8's Avatar
Same....
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Rover P5 3 Litre Mk1
OzriderXR8 is offline   Reply With Quote Multi-Quote with this Post
