Old 02-11-2016, 09:55 PM   #1
Mondoman
Default MC Wagon chrome strip
Can anyone advise how to detach the shiny metal "protection " strip from the back ledge of the wagon. It needs to be replaced due to a "mishap". Apart from a wrecker, where is the best source for a new one?
Mondoman is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2016, 10:33 PM   #2
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: MC Wagon chrome strip
wreckers ebay/gumtree or overseas would be my guess.
Old 02-11-2016, 10:37 PM   #3
GTLEGEND
Is this the part you are referring to?
Old 02-11-2016, 10:45 PM   #4
GTLEGEND
Or are you referring to part 17K922B from the below?
Mondeo MC Rear Bar.pdf
Old 02-11-2016, 11:22 PM   #5
Mondoman
yes 17k922B
Old 02-11-2016, 11:43 PM   #6
Mondaveo
Mondaveo's Avatar
I think it's the rear bumper protector/scuff plate that Mondoman is referring to (indeed part 17K922B in the posted pdf). (Edit: beaten to it)
I believe it's simply affixed with adhesive, so it should just be a matter of wrestling it off. You could try injecting a glue remover/cleaner like Oomph under the plate to help it pry loose.
You can get a new one on ebay, both genuine and third-party options should be available. (I've looked before as mine also has a dent in it, but I haven't been game to go through with trying to remove and replace it.)
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift GISS sensor: Nov 2016
- hail damaged repairable write-off: Dec 2023
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2016, 12:00 AM   #7
GTLEGEND
That part has a part number of BS71 17C979 AB genuine Ford.
It is not in the Workshop manual I have, just how to remove the whole bar.
I have my car booked into my dealer tomorrow, so will see if they have one and check it out for you..
Old 03-11-2016, 07:23 AM   #8
Mondoman
I look forward to your reply. I will try mild heat first, then solvent iy that doesn't work.
Don
Old 03-11-2016, 09:40 PM   #9
GTLEGEND
They did not have one there, but are getting me some photos of one to see. They said to give them a couple of days..
Old 03-11-2016, 10:43 PM   #10
Mondoman
I look forward to developments and thanks.
Don
Old 04-11-2016, 09:46 PM   #11
GTLEGEND
Hi Don,
I have seen the part you are talking about but having dramas uploading the photo.
To confirm the back of it is like one big piece of double sided tape, so a plastic scraper or trim removed should be used to pry it up from the sides enough to get your fingers under, then slowly peel it off...
Old 04-11-2016, 11:42 PM   #12
Mondoman
good work
Old 06-11-2016, 08:38 PM   #13
Mondoman
There is a German high quality carbon fibre strip that can be stuck onto the external part of the chrome strip. Seems like a good alternative.
I suspect that the current strip is stuck on with double sided tape.
Don
