Old 22-08-2016, 06:16 PM   #1
paulg850
Default Focus ST - Cruise Control
I don't use cruise control very much. So this might be a dumb question. How do you turn it on ? The manual has an arrow pointing to a 'dial' on the left side of the steering column between Set + and Set -. To some that might mean push it in but it can only move in 2 ways - up or down.
OK, this is what I tried. I'm driving along at say 70kph and I lever the 'dial' switch up. Nothing on the information display - no cruise control on. I lever the 'dial' switch down. Nothing on the information display - no cruise control on..
Sometimes it seems that the 'dial' switches on the speed limiter.
I also tried pushing the Set+ button for about 5 secs and also tried pushing the Set- button for about 5 secs. No cruise control.
Is the CC broken or is my understanding faulty ? Thanks to whoever takes the time to reply. Paul
paulg850 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2016, 06:47 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
Default Re: Focus ST - Cruise Control
Regardless if 12 model or 13 onwards. Also ignore LHD pic.
1- press to turn on Cruise control, or off.
2- reach desired speed and press this will set car at speed.
3- will cancel set speed or resume last set speed if CC hasnt been turned off.
Set+/Set- will speed up or slow down by pressing those.
hope this helps!
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 22-08-2016, 06:52 PM   #3
Victor1
Ya can't get any clearer than that description
Victor1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2016, 06:58 PM   #4
The circled 1 is the on button, after you turn it on, press the + to set the speed to whatever you are traveling. Once it's on, the + and - will adjust your speed faster or slower. The reset cancel button will do 2 things. Pressed when on cruise, cruise will cancel, if you either use the brakes, or clutch in a manual cruise will automatically disengage, so if pressed it will reset to the previous speed.
Old 23-08-2016, 11:04 AM   #5
JVC063
JVC063's Avatar
I use the speed limit function just as much, it works in 5 km/h increments, activate button is labelled LM along side of the cruise button. Works great without getting into trouble with the law....
JVC063 is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2016, 10:15 PM   #6
paulg850
Thanks for your replies, guys.
Thanks for the image DJM. My CC button is slightly different. It has 2 controls: it seems that push down to the left for cruise, push down to the right for speed limit (LM).
So perhaps I'm guilty of pushing it the wrong way for cruise. Thanks for making me look at it again.
