Old 18-03-2016, 01:44 PM   #1
Mondaveo
Mondaveo's Avatar
Default Re: Fuel Tank Capacity
Originally Posted by bundybear75 View Post
Yesterday I filled up at Costco in Fyshwick and whilst being dazzled by the price (97.7) I managed to put in 71 litres. I had done about 1100km and the fuel gauge was still at around 1/8 mark.
How many clicks of the pump did you take to achieve that?
User manual recommends not to put in any more after the second click, elsewhere I've read you should stop at the first click.
Manual mentions expansion space in the tank and there is also the volume going up the fuel filler neck. Is it possible overfilling into those spaces could add up to the extra?
Either way something seems screwy. If your gauge was at exactly 1/8 you should still have had 8-9L onboard... It would seem either your gauge is out (you were running on fumes), or their pump is very wrong...
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift GISS sensor: Nov 2016
- hail damaged repairable write-off: Dec 2023
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2016, 01:53 PM   #2
rondeo
Pumps being mechanical devices may develop faults?
Old 18-03-2016, 02:38 PM   #3
Mondaveo
Mondaveo's Avatar
After some quick reading it seems unlikely that the bowser should be inaccurate, they get checked regularly by the operators and regulators and I imagine the penalties would be steep.
http://www.caltex.com.au/LatestNews/....aspx?ID=13454
If you think the servo's pump is inaccurate you can report it.
http://www.measurement.gov.au/Pages/...the-Truth.aspx
Expansion space is apparently minimum 5%, so a tank designed to hold (say) 70L must do so at a maximum 95% capacity and will actually be a 78.95L (or more) tank.
http://mechanics.stackexchange.com/q...les-vent-trick
Old 18-03-2016, 06:27 PM   #4
rondeo
So about a spoonful either way.
And watch out for bad facts on social media!
Old 18-03-2016, 08:17 PM   #5
bundybear75
bundybear75's Avatar
I filled up until the bowser clicked out, then rounded off to the next even $
I have had Costco bowsers continue to pump until its running out the top of the filler before cutting out so it could be that.
I would be surprised if the bowsers were in-accurate. I was just surprised as I expected to put in 66-68 litres based on distance and avg fuel consumption.
On a side note, the fuel light came on with DTE of about 145km. Is this what others experience? I did travel about 80km before filling so maybe I was running on fumes. At least I know how far I can go.
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2016, 10:26 PM   #6
Mondaveo
Mondaveo's Avatar
My car is down to 110km DTE and the fuel light hasn't come on.
Last time, it came on at around 100km DTE, then went out, and then came back on again later.
For what it's worth, the manual says it illuminates when you reach 80km DTE, calculated from your consumption rate so I dunno why it should come on at any other figure!
