Old 08-02-2015, 05:27 PM   #1
car10002
Default Led light bars
Hi
With the led light bars and driving lights with a maximum of four driving lamps (including LED light bars) can be fitted to a vehicle in addition to the vehicle’s main beam headlamps. Does the 4 maximum include drls
Could you have a pair of fog lamps which is 2 and a led light bar and drls,
Does the driving lamp include drls or just driving/fog lamps
What are sa rules on led light bars
car10002 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2015, 06:27 PM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Led light bars
The ADR's or the NCOP for vehicle modifications (both of which are in the Tech portal) will provide your answer but:
1. You may have up to 4 driving lamps in addition to the headlamps.
2. You may additionally have two fog lamps.
3. You may additionally have two DRL's
An LED light bar is considered to be a pair of lamps (ADR 13 S2.16.1).
Russ
Russ
Observatio Facta Rotae
Old 08-02-2015, 06:33 PM   #3
car10002
Can you have a pair of drls a pair of fog lamps and a small led light bar
Old 08-02-2015, 06:43 PM   #4
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
That's looks fine as stated in the post above yours...
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2015, 06:49 PM   #5
Itsme
Experienced Member
Itsme's Avatar
Yes you can.
Old 08-02-2015, 06:57 PM   #6
car10002
When you say yes you can does that mean one led bar a pair of fog lamps and a pair of drls fitted
Is it 4 including drls or are drls not included or can you still fit the bar a pair of fog lamps and a pair of drls
Old 08-02-2015, 07:10 PM   #7
russellw
russellw's Avatar
How about you read Post #2 again - it clearly states what you can and can't have.
One LED bar = two driving lamps and you are allowed four thus you can have 1 x LED bar and 1 pair of driving lamps plus one pair of DRL's plus a pair of fog lamps.
I trust that clarifies it for you.
Old 08-02-2015, 07:30 PM   #8
Falcman0o7
Falcman0o7's Avatar
Wonder if I'm legal :P
Falcman0o7 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2015, 10:04 PM   #9
car10002
Also what are rules on using led light bars
And is a 72w 12 inch one ok to use
Old 09-02-2015, 08:57 AM   #10
Simple6
Simple6's Avatar
Mate, have you even tried looking for yourself?
I'm sure if you have a Google, you'll fine what you're looking for.
Old 09-02-2015, 10:33 AM   #11
Xauterus
Is there a way of having the roof light legal? Seems to be a real problem
Xauterus is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2015, 06:59 PM   #12
russellw
russellw's Avatar
It will depend on the pattern they are designed for but if they are driving lamp or pencil type spreads then the same rules apply to them as to driving lamps.
Probably not but only by two lamps. Mind you the NCOP is harsh on high mounted lamps - you'd get away with them for 'off road' use as long as they were independently switched - which I suspect they are.
Russ
Old 10-02-2015, 02:33 AM   #13
1TUFFUTE
1TUFFUTE's Avatar
Russ
Russ
Calm down guys it's still confusing......these days you can get led light bars of all sizes. Some setups are one long led bar......others are medium to rectangle, square and short single bars where you'd mount one each side replacing the older spotlight setups.
So if you buy a car with headlights plus it has DRLs......and foggies........you can then fit two long led light bars or four smaller led light bars. As for the rest of the sizes, that would be confusing
1TUFFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2015, 04:46 PM   #14
Falcman0o7
Falcman0o7's Avatar
Russ
Yeh Russ, 2 switches for roof lights. Others come on with high beam ONLY when they are switched on.
I'm in tassie so not sure if the same laws apply to me? We are pretty backwards over here LOL
Old 10-02-2015, 06:47 PM   #15
jmack
Smile Re: Led light bars
Easier to just drive during the day
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2015, 06:48 PM   #16
Itsme
Experienced Member
Itsme's Avatar
Any off road light or roof lights are legal for off road use only, these lights should have covers on them if vehicle is driven on roads otherwise you could be fined.
Old 10-02-2015, 09:14 PM   #17
Falcman0o7
Falcman0o7's Avatar
there is a place somewhere on earth where just as the sun is about to go down it comes back up! LOL and visa versa on the other side with darkness. Trippy ha!
Old 10-02-2015, 10:23 PM   #18
ROOSTA
DFDFDF
ROOSTA's Avatar
Going to North Alaska in June.. 63 days of constant daylight... Come november the suns disappears for 60 odd days, still illuminates the sky for a few hours a day though..
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2015, 11:40 PM   #19
BPXR6T
Fitted a 52" roof mounted dual row flood/spot led light bar to the jeep the other day. Throws out awesome light. Independent switch for offraod. I drive a lot of dirt tracks late at night. Roo city out here. Amazing how many roos I see now that I never even knew existed before. Cops here are sensible and pragmatic, they know its needed for safety. They only get a bit bent out of shape if the roof lights are wired into the high beams.
BPXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2015, 12:31 AM   #20
1TUFFUTE
1TUFFUTE's Avatar
That looks great. I'm trying to convince my bro to go a full light bar like this on his unlimited jeep. but he's not realized the world has moved on from big round spotties . Pretty sure his current bulbar mounted spotties are linked to his high beam tho!
As mentioned above tho.....I've NEVER seen a cover for an led light bar yet.....do they not need them?
Old 11-02-2015, 08:41 PM   #21
Falcman0o7
Falcman0o7's Avatar
Thats cool! Enjoy
