19-10-2014, 07:15 PM | #1 | ||
hi, im not sure if there is a another post like this but, i was wondering what is the best spark plugs for a 2009 focus LV LX... so far ive seen NGk IRIDIUM, PLATINUM and stock spark plugs. What would be the best for performance?
Thanks for the help. |
19-10-2014, 07:41 PM | #2 | ||
Effectively little to choose between them for performance on that engine - the main difference between the plugs mentioned is life expectancy.
Cheers Russ
19-10-2014, 11:04 PM | #3 | ||
I bought a set of NGK iridiums from op oils for $52 shipped when my plugs where due about year ago. I've also tried autolite 103s, but cant remember if i noticed a difference. I traded the car in a week after installing.
20-10-2014, 06:24 PM | #4 | ||
we use the NGK range.
The way we see it is if your using a plug with a shorter life expectancy to save some money, in the long run it doesn't save you money if paying a workshop to replace them as most workshops have a minimum half hour labour charge for any work.
Advertising removed. |
20-10-2014, 08:34 PM | #5 | ||
any particular spark plug, a link from ebay or a shop like supercheapauto would be nice
thank you |
20-10-2014, 09:44 PM | #6 | ||
I meant Opie Oils
21-10-2014, 10:07 AM | #7 | ||
Like what model ngk did you get
21-10-2014, 04:51 PM | #8 | ||
The recommended NGK plug is ITR6F13, which is the iridium plug
Cheaper to import from UK via eBay |
21-10-2014, 08:55 PM | #9 | ||
