Is it normal to lose water level in the overflow tank over time?
TDCI Focus with 75,000km on the clock, my coolant level is just a bit under the minimum indicator. I haven't noticed any leaks inside the car at all, though the other night there was some water in the footwell on the floor mat, but my passenger stepped in a puddle accidentally before she got into the car so I'm guessing its from that. |
Generally you should not be loosing any coolant at all because it is a sealed system. It is a sign that you have a leak. Sometimes the leak is not visible from the top if you just pop the hood up. I have a leak on my focus just after 20,000 kms and I only noticed it when I was changing the oil myself and I was under the car. The red/pink coolant was very visible under the was pump and some of the pulleys from underneath the car but not visible if viewed from the top of the engine.
If I remember right, the cap seals on o-rings. There have been cases where the bottle distorts and the opening is no longer round so the o-rings don't seal properly. If you can't see any obvious residue from a leak you could consider this.
At the moment its half way between empty and the minimum mark on the overflow bottle.
Just wondering how this turned out.
Was it the heater core leaking or something else? Cheers. |
radiator is one of the common leak points on the Focus mk2 - end caps.
Have the system pressure tested. Last 2 we did were both XR5s @ 60k service.
Advertising removed. |
Over Thinker
thats low kms to have this sort of problem
very strange .... petrol and diesel engines available .. nice car this artical . writer must not like ford focus .. http://www.whatcar.com/car-news/comm...oblems/1201320 all used an oil cooled turbo if fitted I see if it had a water cooled turbo fitted - I would be looking at the turbo internals
My car goes Brumm Brumm Last edited by dirty hands; 07-10-2014 at 06:20 PM. |
I've pressure tested system, it very slowly loses some pressure, as in over an hour period, very slowly.
#10 | |||
Pressurise the system and inspect all hose connections and the radiator end tanks fully whilst under pressure. If no visible leak is found, pressure test the cap. If that all checks out I would start looking at an internal leak such as head gasket. Never seen a turbo leak coolant internally only at the sealing washers which will give you an external weep/drip during pressure testing.
#11 | |||
Where to next??
Perhaps it's losing pressure from the actual testing unit? Set it up again, and if the pressure slowly drops again spray soapy water around the fittings and see if it bubbles up.
#12 | ||
The other less desirable choice is leaking at the water pump Is the pump external or inside the timing chain cover in which case you will need to look at the small drain hole at the bottom of the cover under the pulley to see if there is coolant stains down there
