Old 27-08-2014, 02:00 PM   #31
_Ben
_Ben's Avatar
Default Re: E85
Originally Posted by simon varley View Post
I don't really know how the haltec sensor works and the website doesn't explain it as far as I can see. I know that Ford use a knock sensor on the block of their FFV cars to adjust timing based on octane rating. The 2.5 Ranger is flex fuel up to 100% for South America.
From what I've read, you make tunes at various ethanol ratings - one on straight 98 (or whatever), one on E85, and a few between. The e-Flex sensor tells the ECU what % of ethanol there is, and then the fuel map for the relative amount of ethanol is used.
_Ben is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2014, 02:42 PM   #32
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
Default Re: E85
I get all that - just can't figure out how you can determine % ethanol from this sensor. I assume some kind of conductivity or resistivity measurements?
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2014, 02:59 PM   #33
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Default Re: E85
Ford's ecu pulls spark based on a knock event, it does not change to a different fuel map, it does not allow for the use of a flex fuel sensor to change fuel or spark maps based on ethanol percentages.
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2014, 12:39 PM   #34
johnydep
johnydep's Avatar
Default Re: E85
So far the E85 performance improvement is great, I like it. I am noticing the fuel gauge dropping faster, which I don't like.
For the slightly better power, I don't think the extra fuel use makes the fuel worthwhile for street use. I might try one more tank fill, but after that I'll only use it for strip use.
The true danger only occurs when you take a potentially dangerous piece of machinery
and place it in the hands of the most unpredictable species on the planet.
Human behaviour, as history has catalogued, cannot account for what any persons actions may be,
especially concerning their love of the motor vehicle.
http://www.fireservicecollege.ac.uk
johnydep is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2014, 07:23 PM   #35
F250_dually
Default Re: E85
I've been using E85 for about two months now. Can't say I've noticed an increase in HP though I haven't retuned. Mileage has been slightly better but that may be due to more highway driving. I have however noticed more exhaust steam in the mornings but again that could be due to the cooler nights?
F250_dually is offline   Reply With Quote Multi-Quote with this Post
