Old 18-06-2012, 08:23 PM   #31
mik
mik's Avatar
Default Re: Thermo fan always on
how did you go Uncle Ken?
Old 18-06-2012, 08:32 PM   #32
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
The only answer is to fix the car properly , the fans are on for a reason
The car is in limp mode and affecting other things . Take it to a professional and have it looked at .
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2012, 08:42 PM   #33
MGM
MGM's Avatar
My fans have been on non stop for 6 months, it's a trans temp sender faulty, the wiring for it is $260 alone then labour to fit.
MGM is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2012, 07:35 AM   #34
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
What happens (or doesn't) when an AU is in 'limp mode'? I have no idea.
UK
Old 19-06-2012, 08:42 AM   #35
GK
Walking with God
GK's Avatar
UK
Car is stuck in 3rd to protect the transmission.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 19-06-2012, 12:24 PM   #36
Uncle_Ken
Uncle_Ken's Avatar
GK
Thanks GK Will check on the way home today.
I'll be in Melbourne this weekend
Uk
Old 19-06-2012, 01:14 PM   #37
GK
Walking with God
GK's Avatar
Uk
You'd surely know if you were in LHM. The car takes off in third. I've had it happen a few times, in the early days of trying to put a Tickford dash into the wagon. The temp gauge wasn't working and the ecu put the auto into LHM to protect it.
Once JC fixed (he's particularly good at doing that) the pod in the dash (replaced it with one from another high series dash), it was all good, and has been ever since.
GK
Now gone!
On LPG
Old 04-07-2012, 10:21 AM   #38
Uncle_Ken
Uncle_Ken's Avatar
Update..
Got the car to a sparkie today. Turns out one of the two fans had 'jamed tight'. So the second fan was spinning twice as fast to make up for it. Will have a closer look today to see what caused the drivers side fan to jam in the first place.
UK
Old 13-06-2014, 05:16 PM   #39
bf taxi
hi I have the same problem as fan stays on but have noticed ac is on it does not display on at the console at all but the compressor is still engaged so my ecu thinks ac is on so I can not turn fans off without removing fuses I have disconnected wire at front of compressor so that stops running could it be ac switch on console be at fault
bf taxi is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2014, 07:57 PM   #40
Uncle_Ken
Uncle_Ken's Avatar
Bugger. Mine was just the fans in the end. After I put in a new one one problems
UK
Old 15-06-2014, 08:24 AM   #41
GK
Walking with God
GK's Avatar
Job done!
GK
Now gone!
On LPG
Old 26-06-2014, 08:29 PM   #42
bluestripes
Q - CAR
bluestripes's Avatar
Hey Uncle .... just read quickly though your post and it seems you needed to replace your fans to resolve problem?? Correct and if yes ... where did you buy fans from ??
Reason - my car has the same issue ... and looking to your resolve.
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2014, 08:58 PM   #43
Uncle_Ken
Uncle_Ken's Avatar
Hi Bluestripes,
I went to pic and pay less, got one out of 'good' wreak, checked I could test it on the spot, took it outside and powered it up straight away to check they worked. All good.
didn't cost to much. Did the same when my son in law smashed my old AUII and wreaked the fans.
UK
